Pedal order question
Discussion in 'The Tone Zone' started by chromeboy, May 20, 2019.
  1. chromeboy
    chromeboy Active Member
    Jan 25, 2010
    475
    173
    San Bruno,CA
    Hey guys, just a couple of questions on pedal order. Now I am running a chorus pedal and digital delay into the effects loop of my jet city 100hdm head and just added a digitech ricochet pedal into the same loop but haven't tried it yet. Just letting you know a little about my pedalboard. Now my pedal order as of now is my pedalboard wireless into my volumes pedal, into my wah pedal, into my univibe pedal, into my noise suppressor, into my ocd via the loop of the noise suppressor. Should the univibe be before or after the ocd and should it be used in the loop of the noise suppressor? Your thoughts?
  2. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    3,812
    2,910
    Montreal
    Re Uni-vibe. Pick your poison. Trower before. Hendrix after. Ultimately you'll decide which sounds best to your ears.
    Why noise suppressor so early in the chain. I thought it would go after all of the noise makers?
    Sorry. No idea about loops in noise suppressors.
    BP
  3. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,021
    1,747
    Wa State
    Depends on the unit .. Boss NS-2, as an example, is a Sidechain Gate .. Trigger 1st in line after Wah or Fuzz .. Reduction loop Gated at End ..
    Mitchell Pearrow and BanditPanda like this.
  4. ricksconnected
    Sep 29, 2015
    12,689
    5,845
    everywhere you wanna be.
    noise gate is the last thing in my chain period.
  5. bad565ss
    bad565ss Well-Known Member
    Apr 5, 2015
    216
    281
    Waterford, Michigan, USA
    I have no amps with loops. Marshalls and Supros. On my board I run wah, compression, dirt, clean boost, tuner, and gate in that order. When using any modulation of time effects they go after boost. There really are no hard and fast rules per se. My setup is pretty standard though.
    matttornado and Mitchell Pearrow like this.
  6. matttornado
    matttornado Well-Known Member
    Mar 14, 2012
    825
    335
    I like my Boss Chorus and phase 90 in front of my amps (Superlead & DSL) and the delay and EQ in the loop if the DSL.
    When using the superlead, same thing but i run a line out to the delay and EQ then to
    another amp.
  7. fifteenohms
    fifteenohms Active Member
    Sep 30, 2010
    386
    198
    Los Angeles, CA
    My first thought is how anything I ever got from Digitech now resides in my parts pile.
    ricksconnected likes this.
