Peavey Windsor Loud Hum
Discussion in 'The Workbench' started by JM5010, Mar 24, 2020.
  1. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    Hi guys, i have a peavey windsor that hums loudly when the standby switch is turned on...
    This happened after i tried to wire in a JCM 800 style “low input” to use woth pedals. Was working fine before this.
    I’ve troubleshooted by removed preamp tubes, checked my wiring, checked my speaker, and even tapped the filter caps with a popsicle stick to see if that’s the issue.
    Dunno what to do, any suggestions?
    BTW, the amp is wired like the Green Day “Dookie Mod” (modded 2203ish schematic). Sounded great when it was working...
  2. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    Update: The hum seems to be originating from the PI tube area. Also, there is sound coming from the amp if i plug in my guitar.
    Here are my schematics if it helps.
  3. marco_giampa23
    marco_giampa23 Active Member
    Feb 11, 2020
    223
    183
    probably a loose ground, depends on the type of hum though
  4. ampmadscientist
    16,545
    10,454
    Put the tubes back in.
    Plug guitar into the effects return.
    Turn the amp on, is there sound now?
    From what you are telling me so far, it's an input jack wiring error.
    Put the jacks back to stock and re-test the amp.
  5. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    My amp doesn’t have an FX loop, i actually took it out of the circuit.
    Will rewire the jacks to how i had it before.
  6. ampmadscientist
    16,545
    10,454
    Did it work before you wired in the extra jack?
  7. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    It did. However, the input jacks don’t seem to be the problem. I just wired it back to stock and the hum is still there.
    What usually causes this type of hum? What other places should i check for issues?
  8. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    May have found the culprit: R22.
    It’s that big white resistor which is part of the bias circuit...gets hot to the touch and seems “crumbled” in the pic. Could this be it? I don’t think i moved the bias pot at ALL, the tubes aren’t red plating or anything.
    If not, where else can i look for any issues? @ampmadscientist
  9. ampmadscientist
    16,545
    10,454
    Take out the preamp tubes.
    Leave the PI tube installed.
    Leave the power tubes installed.
    Turn up master volume to 10.
    Turn channel volume to 0.
    Does it still have the hum?
    JM5010 likes this.
  10. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    Yep, still has the hum.
  11. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    Also, there’s a more prominent “buzz” when the master is at 12 o’ clock. Then it goes back to the hum from before once the master is maxed.
  12. South Park
    1,714
    1,336
    Some thing is not grounded right in the input . Try to relocate the ground
    JM5010 likes this.
  13. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    I’ve tried that^ already with no luck...should i look in the mixer areas? (470k res/470p cap area)
  14. ampmadscientist
    16,545
    10,454
    What happens when you take out the PI?
    Just the power tubes in does it still hum?
    JM5010 likes this.
  15. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    It only hums with the PI tube in.
  16. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    Jesus christ...was messing with the master volume pot and pulled it and the hum stopped...
    So i put on the washer and bam! LOL! hum gone!
  17. ampmadscientist
    16,545
    10,454
    I don't exactly understand how your master is hooked up but I'm happy you fixed it...:fever:
  18. mickeydg5
    mickeydg5 Well-Known Member
    24,035
    11,021
    So as long as you run the washer the hum cannot be heard, correct?
    Wenander and JM5010 like this.
  19. South Park
    1,714
    1,336
    The pot was not grounding out right
    myersbw likes this.
  20. JM5010
    JM5010 Member
    Nov 11, 2017
    148
    22
    Correct. It’s so weird...it is what it is.
