Peavey 6505 MH 4 ohm mod?
Discussion in 'Other Amps' started by Ryan Morris, Feb 3, 2020.
  1. Ryan Morris
    Ryan Morris New Member
    Jan 23, 2020
    14
    5
    I'm looking into buying a Peavey 6505 MH but I noticed that the amp can only be run at 16 or 8 ohms. Does anyone know if there's an easy mod to make it work at 4 ohms?
    For example, I had a JCM 900 head, switchable from 8 to 16 ohms, However, you can go into the amp and resolder a connection on the transformer so it can run at 4ohms, like the JCM 900 combos do. Is there a way to do that with the Peavey 6505 MH?
  2. pedecamp
    14,133
    10,784
    Youd be better off asking this question in the workbench section, and even better off at the Peavey website.
    This is an amp that fell short of being a great amp, I found that you could only dial in 1 channel at a time, if this is all you need then this is a great amp, but if you want to use this amp as a channel switcher thats where it falls short, plus its got lots of great features that would only be useful with a channel switching amp so not so useful as a single channel amp. Depending on your needs Id get something else like the DSL20HR.
    You have a 4 ohm cabinet? Probably easier to rewire the cab to change it from parallel to series, a pair of 8 ohm speakers wired in parallel is 4 ohms, change the wiring to series then the speakers will give you 16 ohms.
    wakjob likes this.
  3. mickeydg5
    mickeydg5 Well-Known Member
    24,059
    11,044
    If it is like the other 6505 the schematics show only the two output taps.
    Anyone have a schematic for the 6505MH?
  4. ampmadscientist
    16,589
    10,498
    Peavey is cool about giving you schematics 601 483 5365.
    When I started as a PV service center in 1970s since then they have always provided parts and drawings without fail (let's hope so).
    Gunner64 likes this.
  5. Gunner64
    Nov 16, 2013
    5,784
    7,144
    Midwest, USA
    I do know that the 6505mh has some heat issues, at least mine did and will overheat after an hour of moderate volume and go into protection running in the 16 ohm postion, I would hesitate running it at 4, if it's even possible.
  6. Gunner64
    Nov 16, 2013
    5,784
    7,144
    Midwest, USA
    I have called them in the past and they are excellent in this regard. Even if you are not an authorized service center they bend over backwards to get you what you need.
  7. ampmadscientist
    16,589
    10,498
    Dude, the bench techs will get on the phone and help you if you ask.
    wakjob and Gunner64 like this.
  8. MickeyJ
    MickeyJ Well-Known Member
    Nov 11, 2019
    1,062
    578
    To the Op, i'd check and see if this is the case with yours, if it is, i wouldn't be trying to get it to run on 4 ohms, I'd be listing this for sale and buying a real amp.
  9. Gunner64
    Nov 16, 2013
    5,784
    7,144
    Midwest, USA
    And he's gone...
  10. Ryan Morris
    Jan 23, 2020
    14
    5
    I don't have one yet, I've been considering buying one and I wanted to see if a 4 ohm tap was possible before buying one.
  11. Ryan Morris
    Jan 23, 2020
    14
    5
    To everyone, I appreciate the insight into the possible overheating issues! I've never played one, only seen YouTube demos, and to me it sounds almost exactly like its bigger cousin, but overheating is something you don't find out about until you've stress tested it, which most YouTube demos don't do.
  12. Ryan Morris
    Jan 23, 2020
    14
    5
    I'll definitely try and get in touch with Peavey about it, thanks!
  13. Gunner64
    Nov 16, 2013
    5,784
    7,144
    Midwest, USA
    I really liked how it sounded. I gave it to my brother and he is actually the one who is having overheating issues with the head I'm refering to.
    Upon googling it sure enough there are issues. After talking with my brother, who called Peavey, there apparently is a problem with a thermisistor in the protection circuit. Apparently they went a little tight with the tolerence of this part, and it goes into protection prematurely. I do believe they recommended a fix, which has to do with upping the value of the thermisitor iirc.
  14. Northwinds
    Northwinds New Member
    Feb 14, 2020
    13
    21
    This is the first time I ever heard of a 6505 mini head! I have the USA made 2x12 original combo which is the same as the 5150 still and it is a 2 channel amp with 3 button foot switch. Is this MH true to the original 5150 design? I heard changes were made shortly after all production went overseas. I admit I am not in the loop on amps like I used to be
  15. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,407
    1,360
    Why? Any 2x12 or 4x12 that's 4 ohm cab easily be rewired to 16 ohm
    It's easier and safer to mod the cab
    Northwinds likes this.
  16. Evil Z06
    Evil Z06 Active Member
    Dec 6, 2011
    156
    112
    Pembroke Pines,FL
    The earlier ones had some overheating issues but not the later ones.....I can run mine all day and no problems
    Jethro Rocker likes this.
  17. ampmadscientist
    16,589
    10,498
    True, but also cool if it has another tap on the tranny maybe?
  18. Ryan Morris
    Jan 23, 2020
    14
    5
    I have 2 8ohm 2x12 cabs and I'd like to be able to run them both at the same time. I could rewire them to have 32ohms each, but then I HAVE to use both of them.
  19. solarburnDSL50
    Aug 8, 2008
    16,045
    10,314
    Wetville
    Who gives 2 fux about Peavey when Farah Fawcett smiles? No one.
    Best avatar evar.
