Partridge style OT 8K or3.5K taps
Discussion in 'Building the Classics' started by Rotorcraft230, Jan 1, 2020.
  1. Rotorcraft230
    Rotorcraft230 Active Member
    Aug 15, 2019
    261
    179
    F1DE91D0-C6FB-48C1-85FB-4376BCF86812.jpeg F5EECD44-B6D6-48B0-B4D5-1C8B02C6D869.jpeg Amp is a Trinity Triwatt HIWATT DR103 cline
    So I’m getting ready to hookup the OT and it has 2 sets of inputs. The manual says to use the 8K taps but it also has 3.5k taps as well.
    My question is what would be the difference between the 2. Here si a few pics of the build.
  2. South Park
    1,232
    927
    It is how much resistance the the speaker has over the power tubes.
  3. neikeel
    3,654
    2,077
    The important thing is the ratio between primaries and secondaries and the type of tubes you are going to use. A normal Hiwatt uses EL34/KT77/6CA7 etc. and would use the 3.5k option.
    The kit you have bought has probably got 6V6 and in that case use the 8k option.
    These are the reflected impedances that the output tubes 'see' and 8k works best with 6V6.
  4. Rotorcraft230
    Aug 15, 2019
    261
    179
    Thanks for the answers. Neikeel, I forgot to mention we are putting KT66 in. The amp is designed for both, actually I can run
    6V6
    KT66
    Or EL34s
    There is a switch for 6V6/KT66 tubes
    If I choose EL34 I have to change a resistor. But this amp is gonna get KT66. Would I still use the 8K tap for the KT66 tubes.
  5. Rotorcraft230
    Aug 15, 2019
    261
    179
  6. ampmadscientist
    14,866
    8,725
    The 3.5K taps go to the screen grids. The 8K go to the plates.
    It's an ultra-linear transformer. (which is an advantage actually)
    The ultra linear configuration allows the bias to be set cooler, but maintains the lower distortion of a hotter bias.
    But more like this actually:
    So if your'e running it push pull instead of ultra-linear, you just use the 2X 8K outer taps alone.
  7. Rotorcraft230
    Aug 15, 2019
    261
    179
    Excellent answer!! Gonna use the 8K taps.
    I didn’t know how much fun it was building amps and how much I’m learning.
  8. neikeel
    3,654
    2,077
    Unusual to have UL with 43% taps in a Hiwatt clone but useful nevertheless. 8k will be fine with KT66 and 6V6 although you would have to switch taps or switch down to half your speaker value on amp selector for EL34s.
  9. ampmadscientist
    14,866
    8,725
    The ultra linear operation IMHO is much better.
    You can get lower distortion with less heat and save some wear and tear on the output tubes.
  10. neikeel
    3,654
    2,077
    Yes, great for a bass or hifi amp, can't think of many guitar amps that sound great with UL OTs, but I am prepared to be educated?
  11. Rotorcraft230
    Aug 15, 2019
    261
    179
    Neikeel, I just herd back from the designer of the amp and that is exactly what he said about the impedance. The previous OT he was using didn’t have the 3.5k taps and said if EL34s are used you have to cut 1/2 the impedance. Now that the taps are there use the 3.5k with EL34s and just match up the impedance selector to the cabinet no more cutting in half.
    Ampmadscientist So on the other hand if I’m using KT66 tubes I can use the 3.5K taps to pin 4 and 8K taps to pin 3. That gives me less distortion and. Cooler bias? Not quite understanding the benefits of it!
    Thanks Mark
  12. mickeydg5
    23,255
    10,332
    Please do not confuse his build.
    The manual/builder's guide tells him exctly what to do and use. It does not use ultra-linear and has a B+ node for the power tube screen supply along with screen resistors.
  13. ampmadscientist
    14,866
    8,725
    Is somebody confused?
  14. mickeydg5
    23,255
    10,332
    I would say he will soon be thanks to your modification implementations to his kit build mentioned above.
  15. MickeyJ
    MickeyJ Active Member
    Nov 11, 2019
    303
    207
    Using that 3.5k tap like that, pinning them to pins 4 ( and running the 8k taps to pins 3) will have the amplifier running in what's called ' ultralinear ' mode, or ' UL'. UL usually has taps at 43 percent for screens. UL is good for monitor systems, home stereo and any application that doesn't require or would be offended by the associated distortion/compression.
    They run cleaner with more headroom.
    Also, you don't need a choke.
    If I was you , I would decide if I wanted some grit, or not.
    People bag out UL in guitar amps, but they've never heard a late silverface super reverb in full flight, my god what a tone monster ( however they're not at 43 percent, only 12 ) ( you may note that 3.5k is around 43 percent of 8k)
    My hunch is that you'll prefer no UL connections ( you just tape them off and run a choke and hook up pin 4 as ' normal'.
    You can very easily try the amp one way, and then the other and then just decide, or just do what mickeydg5 implies and just build it exactly as the instructions want you to.
    if you want to run kt66 without UL, Just use the 8k taps and tape off the 3.5k taps.
    if you want to run kt66 in UL, hook up 8k taps to pins 3, and 3.5k taps to pins 4.
    if you want to run el34, just run the 3.5k taps and tape off the 8k taps.
    you may try the el34 using the 8k taps ( and tape off the 3.5 k taps ) you may like what you hear.
    similarly, you may want to run the kt66 using the 3.5k taps ( and tape off the 8k taps)
  16. Rotorcraft230
    Aug 15, 2019
    261
    179
    Not confused
    Well saidMickeyj, I am doing what the Designer calls out for which is
    6V6 or KT66 use 8K taps only
    EL34 use 3.5K taps only.
    Lots to learn thanks guys for elaborating on all your extensive knowledge I’m having a blast.
    Mark
    MickeyJ likes this.
  17. Rotorcraft230
    Aug 15, 2019
    261
    179
    Oh there isn’t a choke on this build. Any reason why?
    Pros?
    Cons?
  18. MickeyJ
    Nov 11, 2019
    303
    207
    beautiful wiring job btw, be proud of yourself, that's military precision.
    for what it's worth, I'd advise to stay away from metalized films for this build, try and use or consider film foil. Metalized film signal caps have a boldness to them that would accentuate that bulky iron, film foil are a little ' soft' sounding and would even it out a bit, make it more warm.
  19. MickeyJ
    Nov 11, 2019
    303
    207
    no choke means they want you to use a resistor, resistors are good, nice and quiet.
    and more sag.
  20. ampmadscientist
    14,866
    8,725
    Sounds like they are using a 100W 4 tube ultra linear output transformer for a 50 watt amp.
    That is kind of weird that they would use that particular transformer...
    Well you can use a choke if you want to but sometimes causes a low frequency resonance. So it could be a good thing it could be a bad thing.
