Overdrive Suggestions?
Discussion in 'The Tone Zone' started by Rodney, Nov 5, 2018.
  1. shooto
    shooto Well-Known Member
    Oct 22, 2011
    1,943
    1,059
    Denver, CO
    Distortron or Supro Drive
  2. Jeff Hudson
    Jeff Hudson Active Member
    Jul 10, 2016
    228
    205
    Levelland Texas
    The two best drive pedals I have ever used are the Keeley moded Blues Driver and the B K Butler tube driver.
  3. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,906
    6,642
    Montreal
    OK...I didn't listen to the John Mayer clip however I just learned yesterday of the new pedal release from Freidman called the Golden Pearl. This link takes you to Friedman's explanation of the pedal and it's functions. Pete Thorn also has a demo out now.
    I like the available options and the sounds.
    Give'er a listen. May fit the bill.
    BP
  4. chromeboy
    chromeboy Well-Known Member
    Jan 25, 2010
    586
    276
    San Bruno,CA
    Personally I like the OCD pedal. I find it very versatile and it has a very simple layout. Sometimes simple is better. Too much adjustments are really only for your ear. If gigging your audience won't notice. Amp settings are crucial when talking about a specific sound like that you are seeking to achieve. Good luck in finding your sound.
  5. J E H
    J E H Active Member
    Apr 4, 2018
    249
    99
    I have OCD Boss compression/sutainer A Boss Distortion pedal, 2 distortion channels in the Marshall and the two distortion channels on a Fender. I can usually find a sound with one or more of those.
  6. Classicplayer
    Classicplayer Active Member
    Mar 11, 2008
    196
    51
    JEH & chromeboy: What is you method for tweaking your
    amp with the OCD? Most advice I've seen about setting an amp is to first, get the amp to the point of crunch without the OCD engaged, then tweaking the amp's e.q. and last, dial in the OCD.
    I've been researching OD pedals and the OCD keeps buzzing around in the back of my mind. if not that, the
    Maxon 808.
    classicplayer
  7. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    5,319
    3,526
    Bay Area, CA
    Wait for the Metropoulos SuperBoost to hit the market next year... I'm very intrigued by it based on George's demos of the prototype boosting a clean Fender BF and an overdriven JMP 2203...
  8. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,248
    1,010
    Saginaw MI
    Try a TC Electronics Mojo Mojo...only $50 New
  9. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,646
    2,566
    I have about 5 OD pedals myself
    80s Tube screamer, Soul food, Boss OD-2, DOD juice box, Joyo Plexi drive, Coolmusic Crunchy od, Mr. ED,
    My friend has a couple he let me try, Double trouble and the bes one ive ever used so far was his Joyo ultimate drive. He said its a clone of the OCD pedal iver never tried a real one but the ultimate drive on the clean channel of my Fender super champ turns that little thing into a beast.
    Ide get an OCD but there are so many versions
  10. mtm105
    mtm105 Well-Known Member
    Feb 11, 2014
    3,999
    3,883
    NW NJ Exit 25
    ignore the corksniffers.
    ToneBone has worked very well for many professionals. The older model sells cheap. Get the 16 Volt adapter.
    quality construction. Made in Canada. eh?
  11. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    887
    700
    Cleveland, OH
    I've tried them all and the Barber Direct Drive Compact is the winner.
    Great with Les Paul or Strat.
