Original White 1972 Marshall
Discussion in 'Let's Talk Vintage' started by pleximaster, Nov 8, 2018.
  1. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,482
    1,526
    Finished the restoration of this beast! Real metal machine with its philip yellow caps! Its feels as if its on full tilt with the volume on 1 and then the gain goes on to 11!
    plexi
    IMG_1215.JPG IMG_1217.JPG IMG_1205.JPG IMG_1206.JPG IMG_1207.JPG IMG_1208.JPG IMG_1209.JPG IMG_1210.JPG IMG_1211.JPG IMG_1212.JPG
  2. boola1
    boola1 Active Member
    May 17, 2016
    311
    212
    Nice work! My 71 is more or less the same config but with mustards. With some high output pickups and a strong right hand you can do Kill em All without pedals! Love this era!
  3. neikeel
    3,657
    2,081
    Looks good
    The yellow chicklet caps are supposed to have more bite, is that the case? Odd to see both V1 couplers at 0.022uF.
    Are the pi output couplers original? If so what are they. Never seen those before.
  4. pleximaster
    Feb 6, 2012
    1,482
    1,526
    I don´t know looks ok but I did´t touch anything there...
    plexi
  5. neikeel
    3,657
    2,081
    I can’t tell if the joints are touched- what do you think?
    The way the gain kicks in early sounds pretty typical. I’ve had 100w and 50w this era but not with all those caps.
  6. BadgerO
    BadgerO Active Member
    May 27, 2016
    202
    74
    Tehran- Iran
    I have a 72, 1986. Came without transformers but had a lot of rat poop and dead bugs. I turned it into a 1987, it's a proper beast now. :cheers:
  7. pleximaster
    Feb 6, 2012
    1,482
    1,526
    I think they are original look the same...
    An other thing... When did marshall stamp both the steel chassis and the all backpanel with the serial number?
    plexi
  8. neikeel
    3,657
    2,081
    Never seen that before.
  9. pleximaster
    Feb 6, 2012
    1,482
    1,526
  10. neikeel
    3,657
    2,081
    Sorry I cannot see the chassis top lip stamps on those two (do I need new glasses?)
  11. pleximaster
    Feb 6, 2012
    1,482
    1,526
    they are located more to the right than on mine on. On the artiste model look just above the inputs to the right.
    plexi
  12. Trapland
    Trapland Well-Known Member
    Dec 5, 2013
    1,175
    1,007
    Minneapolis
    pleximaster likes this.
