Original 18 Watter Mt Question? London John?
Discussion in 'Let's Talk Vintage' started by pleximaster, Oct 21, 2018.
  1. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,482
    1,526
    I have had a discussion with friend about the original MTs of early 18 watter amps... if these Radiospares transformers were only made with "Hygrade" models or if some were originally made with "standard" labeled models as well. He argues that both were used. I am sceptical as the "Standard" lack heater CT and that the "Standard" has 275V HT compared to the Hygrade 300V.
    I have heard both an original 18 watt with known replaced MT (Standard fitted as they are easier to source) and several clones using the Standard and actually prefer the sound of the the lower voltage produce and how the amp preform.
    London John? You are the Combo-King!
    plexi
  2. London John
    London John Active Member
    Jun 16, 2014
    339
    215
    I've only ever seen Hygrade PT's on original 18w amps, 300-0-300 is the standard HT voltage. These came in two versions, the early with the bell cover and voltage tap, and later without the cover nor tap.
    While we're at it, the OT's were either EL84 (most common) or Heavy Duty. At the very end of production, they also used an OT that I am yet to identify, with a cream plastic bobbin. I've only seen a couple, very late '67 or early '68. Interestingly, this last OT is the best sounding in the 18's I've owned. Nobody seems to know who made it.
    CoyotesGator likes this.
  3. pleximaster
    Feb 6, 2012
    1,482
    1,526
    Thanks John!!!!
    Thats my understanding of the MTs as well
    No “standard” MTs
    Interesting fact about the OTs! Could you post a picture of the rare late OT.?
    Best plexi
  4. London John
    Jun 16, 2014
    339
    215
    Here you go.
  5. pleximaster
    Feb 6, 2012
    1,482
    1,526
    Thanks! Cool!
    If I was guessing maker? Partridge?
    plexi
  6. London John
    Jun 16, 2014
    339
    215
    Doesn't look like anything Partridge made to me.
  7. neikeel
    3,657
    2,081
    Any letters or numbers on it?
  8. London John
    Jun 16, 2014
    339
    215
    Nothing....I've asked all the trannie guys I know.....it's a mystery.
  9. ourmaninthenorth
    ourmaninthenorth New Member
    Jan 8, 2016
    17
    England
    What do you reckon to the similarities John? Certainly not a definitive answer by any means, but fairly interesting nonetheless.
    Pennine Radio Ltd choke in an early Matamp Series 2000 (1962) ...this model ran until 1968.
    Same style of slots
    Similarly, in a 69 (ish) Orange ORST,
    Thanks to our mutual pedal Wizard friend for sources on the pictures.
