Origin Mods!
Discussion in 'Marshall Amps' started by CyrusTheFabulous, Jul 9, 2018.
  1. Mitchell Pearrow
    9,030
    13,866
    First off 4 green backs, second time 4 cream backs, and I plan on loading them into the MG cabs, 2 at a time till I can fill them all, and turn them into 16 ohm cabs! Cheers Mitch
  2. MarshallDog
    Nov 28, 2010
    12,798
    12,496
    Taintville
    You may want to try Creamback G12H-75s??? Im liking it a lot in this amp. Just a touch more crispness and character...just a tought.
  3. Mitchell Pearrow
    9,030
    13,866
    I will definitely give it a try, haven’t purchased anything yet, but those are my plans! Cheers for the heads up on speaker types! Mitch
  4. paul hancher
    paul hancher Well-Known Member
    Jan 25, 2019
    272
    476
    if you don’t mind me asking can you give a $ quote on the gain stage and standby mods? i am interested in putting a standby in my 50h. does the power scaling complicate the mods? can the transformer handle an extra pre-amp tube without mods? thanks in advance for your response.
  5. milfwah
    milfwah Active Member
    Sep 6, 2013
    189
    232
    So far my only mods have been twisting the knobs on the amp now and again :)
    Mine is the head and I run it into a two notes capture Then into Reaper and use a greenback 4x12 impulse response then out of my monitors. I can run any of my amps (even the 100 waters) full up this way and the resulting tone is amazing. The origin 20 is no exception.
  6. MarshallDog
    Nov 28, 2010
    12,798
    12,496
    Taintville
    Sounds about right you already are using better speakers IMO. Try some new upgraded tubes and you’ll probably blow your goowwww!!!
    steveb63 likes this.
  7. Capo
    Capo New Member
    May 31, 2019
    10
    Hi all. New to forum, not new to GAS. Just picked up a Origin 50C. Thinking of a) Creamback, b) New Mullard or other tube?, c) swap transformer with Mercury Mag? Waste of time? Just for fun? Not my only amp, so thinking of just fooling with this a bit.​
  8. paul hancher
    Jan 25, 2019
    272
    476
    welcome to the forum! i have a 50 head and my favorite is through a 1x12 with a vintage 30. it also sounds really good with my 4x12 with g12 30h 55hz speakers. i have replaced all preamp tubes with mullard reissues and like it alot. still have the original power tubes in.
    if playing at home the best thing i can recommend is a speaker or power attenuator. it will allow you crank the master. all of the best tones are had with the master above 12:00, and even in the 5 watt setting the amp is still REALLY loud.
    tce63, Capo and Mitchell Pearrow like this.
  9. steveb63
    steveb63 Well-Known Member
    Feb 3, 2010
    325
    627
    Az USA
    My opinion only, speaker swap would be first on the list.
    I'd make sure the speaker is nicely broken in, after reviewing that is when to decide what, if any, steps are next.
    Steve
  10. MarshallDog
    Nov 28, 2010
    12,798
    12,496
    Taintville
    I would highly recommend the Creamback G12H-75 with EH pre's and Svetlana EL34's. Why, it seems as this amp breaks in, it gets darker. Originally, I thought it was a touch brite and put tubes and the G12M-65 Creamback in it. Great! But over time it appeared to lose some bite/balls. So I put this speaker in and tubes and wow! Not brite but it cuts and just sounds great and I DO NOT LIKE BRITE BRITTLE EAR PIERCING TONES AT ALL.
  11. Capo
    Capo New Member
    May 31, 2019
    10
    Can’t believe I waited so long to actually post on these forums after decades of hoarding gear (which won’t stop anytime soon). Great advice and ideas all. Much appreciated. I’ll probably start this journey tomorrow with some speaker research. I’ll keep you all in the loop. Also curious on the transformer.
    Neil Skene and Mitchell Pearrow like this.
  12. Mitchell Pearrow
    9,030
    13,866
    :cheers::welcome: To the best damm forum for Marshall lovers anywhere, glad to see you aboard, and look forward to chatting with ya. Cheers Mitch
    rolijen and tce63 like this.
  13. steveb63
    Feb 3, 2010
    325
    627
    Az USA
    Welcome! Have fun!
  14. Axeplyr
    Axeplyr Member
    May 2, 2008
    55
    57
    OKC, OK
    I’d love a mod to the boost. The jump between off and on seems a bit too much. Maybe increase the gain a bit with the boost off so the boost on isn’t such a big jump.
    Any ideas?
  15. Mitchell Pearrow
    9,030
    13,866
    That boost is the best for a solo boost as is ymmv. Cheers
    El Marin, MarshallDog and tce63 like this.
  16. tce63
    Aug 6, 2018
    1,183
    2,909
    Sweden
    :welcome: To the forum
  17. solarburnDSL50
    Aug 8, 2008
    15,669
    9,246
    Wetville
    Break in your speaker for a month. No on the transformer. Tubes can help. I would choose other OT than MM.
    When you break in the speaker...Choose something that suits your tone/feel. And have fun tuning that amp. It rips.
    Mitchell Pearrow and MarshallDog like this.
  18. Axeplyr
    Axeplyr Member
    May 2, 2008
    55
    57
    OKC, OK
    If the amp has some volume, it certainly works better. And in a band situation.
    steveb63, Mitchell Pearrow and tce63 like this.
  19. Mitchell Pearrow
    9,030
    13,866
    Yes I agree, because I have tried an eq, a clean boost, and nothing seams to boost volume the way the gain button on the foot switch does, and I typically play my origin in a band type situation. Cheers Mitch
  20. Capo
    Capo New Member
    May 31, 2019
    10
    Hello again all. Happy to let you know this thing does, in fact, as expected, rip. So far all I’ve done is run high and mid power, nothing but a holy grail Reverb pedal (don’t have a tank), and have tried the 59 Jazzmaster, 66 Strat, and Epiphone P93. All stock. Absolutely loving this thing. Went on a bit of a jump blues bender when the tone hit me. Think I’ll keep it stock for a little while until I get off this jag and decide I want something else in my ears. Haven’t tried other pedals yet, but have a ton of dirt boxes waiting to get a turn. Probably have 12 of them, so I’ll let you all know what works and what doesn’t. Is there a way to post video here?
