Origin 20h Power Selector
Discussion in 'Marshall Amps' started by steveb63, Aug 25, 2018.
  1. steveb63
    steveb63 Well-Known Member
    Feb 3, 2010
    356
    676
    Az USA
    Thanks in advance for any help in this matter.
    New owner of the Origin 20 watt head.
    My question is, being that there's no standby am I safe to switch from low to high power on the fly?
    Or is it best to power down while selecting power level?
    Thanks again
    Steve
    Jason Fieldhouseespk likes this.
  2. shooto
    shooto Well-Known Member
    Oct 22, 2011
    1,943
    1,059
    Denver, CO
    Just flip that amp off!
    steveb63 likes this.
  3. steveb63
    Feb 3, 2010
    356
    676
    Az USA
    Righton, thanks.
    That kinda felt right.
    Didn't want to do anything boneheaded
    Thanks again
    Steve
  4. Mitchell Pearrow
    10,308
    17,277
    And from what the pamphlet (the owners manual says turn the master to O before powering up)
  5. ampmadscientist
    18,162
    12,181
    It's better to turn the master to zero before turning the power off. It's better to change power level with the power off.
    cgtrman, K2JLX and steveb63 like this.
  6. steveb63
    Feb 3, 2010
    356
    676
    Az USA
    Thanks for the help, much apreciated.
    I couldn't find the answer on the power attenuation question in my owners manual.
    Thanks again HMP, and ampmadscientist
  7. K2JLX
    K2JLX Well-Known Member
    Apr 20, 2018
    310
    620
    New York
    Some users have reported a pop or a thud on switch off also: mitigated by turning the master to 0.
    Mitchell Pearrow and steveb63 like this.
  8. ampmadscientist
    18,162
    12,181
    It's kind of amusing that they left the standby switch out...
    It seems like originally, the standby was supposed to be on the front panel, then was changed to a hi / lo switch.
  9. ampmadscientist
    18,162
    12,181
    If the master volume is turned up high, there is a loud POP through the speaker.
    Hence, the master should be on zero when powering down to avoid the noise....and possibly damaging the speaker.
  10. ampmadscientist
    18,162
    12,181
    What power attenuation question?
  11. steveb63
    Feb 3, 2010
    356
    676
    Az USA
    The high-med-low switch question.
    Sorry, used the wrong term.
    Thanks again, everyone, for so freely sharing your valuable information. Very interesting reading for sure.
    Steve
  12. sjruvolo
    sjruvolo Member
    Aug 7, 2015
    60
    36
    I watched dozens or Marshall Origin videos and not once did I see any of the reviewers power off to change the H-M-L setting. I never heard a popping noise changing power settings. Turning the amp off may be another situation, Almost any amp with no standby switch will make a popping sound when powering off, hence the practice of turning down the volume .
  13. Snowdogyyz
    Snowdogyyz Member
    Feb 19, 2018
    65
    69
    I hear nothing when switching from H-M-L on the amp. There is a pop if you turn it off in low or medium. I always turn it off in 50 watt mode- no pop or noise at all.
  14. Mitchell Pearrow
    10,308
    17,277
    I do know that with the 40c to change power levels it has to be in standby, so with no standby on the origin, I turn volume to 0 power off make the change power back on bring volume back to playing level!!
    ken361 and steveb63 like this.
  15. steveb63
    Feb 3, 2010
    356
    676
    Az USA
    Sounds like a plan.
    I was kinda flummoxed with no standby.
    Every tube amp I've ever played has had one, at least every amp I remember lol. The seventies and eighties were not kind to my memory.
  16. Mitchell Pearrow
    10,308
    17,277
    This is my first tube Marshall with out a standby switch, a lot of controversy about them but I am used to them being on the amp! And I use it.
  17. Jason Fieldhouseespk
    Jason Fieldhouseespk Well-Known Member
    Apr 21, 2018
    326
    473
    I don't get it, there's nothing wrong with not having a standby switch.... Guitar amps don't need them, they were an irrelevant addition that became a popular fad! And then people started thinking that they NEED them!
    The voltages in any guitar amp are simply not enough to damage anything by just switching it on and off, you will do absolutely no harm what so ever doing that, or flicking through the power settings, if you really can't stand the little pop that happens, it will probably be a capacitor, and can be easily fixed, but it's NOT damaging to your amp really....
    Don't stress guys, your fine, guitar amps are fool proof! :)
  18. Jason Fieldhouseespk
    Apr 21, 2018
    326
    473
    Guess what also... this may shock some, but..... THIS amp can even run through the DI out... wait for it... with NO SPEAKER!! :-O
    Turned on, with power going through it, a valve amp... no speakerage!!
    Take what ever you thought you knew about good valve amp practice and bin it guys, plug in and play...
    'Mazin! XD
    Back40, steveb63 and Mitchell Pearrow like this.
  19. Jason Fieldhouseespk
    Apr 21, 2018
    326
    473
    You don't even need to bias the 20w even though they're EL34s...
  20. Jason Fieldhouseespk
    Apr 21, 2018
    326
    473
    Back40 and steveb63 like this.
