Origin 20H Hum when powered on
Discussion in 'Marshall Amps' started by progrockabuse, Feb 18, 2020.
  1. progrockabuse
    progrockabuse Member
    Jul 20, 2019
    42
    74
    Just a quick one, is it normal for the amp to hum loudly powered on? Not a hum from the speakers, just hum from the amp itself. Seems louded than most other amps I've owned.
  2. ampmadscientist
    16,436
    10,342
    Is the guitar cable UN-plugged when it hums?
    Is all the effects UN-plugged when it hums?
    If the output tubes are out of balance it will make a hum also.
  3. Mitchell Pearrow
    9,575
    15,310
    Where’s your volume knob at power up ? If it’s on zero there will be a bit of hum, if it’s up at your playing level it will be more intense !!
    tce63 likes this.
  4. Ken Underwood
    Oct 16, 2013
    467
    1,231
    Annesley North Notts UK
    He has said that it is not coming from his speakers so positioning controls would not make an iota of difference.
    Its remotely possible that the output tubes could be causing the problems but i would be more inclined to suspect the mains transformer or choke, or at a pinch the OT
  5. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    851
    523
    I have at least one head that makes an audible hum when it is switched on. I believe it’s the power transformer powering up. Don’t think it’s a problem. The hum goes away before the tubes are even warmed up.
  6. RCM 800
    RCM 800 Active Member
    Dec 20, 2019
    117
    204
    Ive never noticed any audible noise coming from either of my 20h's.
  7. Deerhunter1972
    Deerhunter1972 Active Member
    Nov 2, 2018
    102
    212
    My DSL20HR hums with nothing plugged into it and in standby. Guessing its the transformer...
    tce63 likes this.
  8. ampmadscientist
    16,436
    10,342
    Take out the first preamp tube, which is closest to the input jack.
    Did the hum go away?
    OK
    after the amp has been turned on 5-10 minutes:
    feel the output tubes and check the temperature, if one tube is cold and the other is hot it's probably a bad output tube.
    When the output tubes are out of balance it can make the amp hum.
    A broken input jack. Broken solder connection at the input jack.
    RCM 800, Mitchell Pearrow and tce63 like this.
  9. Deerhunter1972
    Nov 2, 2018
    102
    212
    Thanks for the advice I'm away from home tonight. I'll try your advice tomorrow. It has hummed since I bought it knew a little over a year ago. I did replace all stock power and preamp tubes with JJ's and still got humming.
  10. ampmadscientist
    16,436
    10,342
    If you can look inside the amp, sometimes parts can break off the circuit board when the amp is shipped. Look for anything that's come loose from the board.
    Once in a while, a capacitor lead wire might break off because of shock and vibration....rarely but it's happened.
    Or if you are not sure, you could always take your amp to a technician.
