Open Jmp-1 Chassis
Discussion in 'Marshall Amps' started by gbirocco, Jul 23, 2017.
Tags:
  1. gbirocco
    gbirocco New Member
    Jul 23, 2017
    The volume pot of my old JMP-1 is very scratchy and noisy so I would like to spray some switch cleaner into it. I tried to open the chassis. I have unscrew the 3 rear screws but nothing happened; I also have unscrew the six little screws on the golden edge (top & bottom) but nothing happened: it seems glued.
    How to open the JMP-1 chassis? Can you help me?
  2. marshallmellowed
    Jun 26, 2009
    3,476
    3,972
    Found this...
    "There are 3 phillips screws in the back and on on the top that must be removed. Then you have to remove 3 allen head screws from the rack mount ears (6 screws total) before it will come loose."
    Dogs of Doom likes this.
  3. gbirocco
    gbirocco New Member
    Jul 23, 2017
    Thank you for your answer!
  4. marshallmellowed
    Jun 26, 2009
    3,476
    3,972
    No problem, hope the info helped.
  5. Dogs of Doom
    20,814
    21,750
    yeah, you have to remove the rack ears...
  6. gjohnson
    gjohnson Well-Known Member
    Oct 16, 2010
    992
    578
    Denver CO
    While its open check for battery corrosion. Mine was leaking and almost destroyed the unit.
  7. gbirocco
    gbirocco New Member
    Jul 23, 2017
    I opened the chassis and I sprayed some cleaner: now the pot is silent, no more scratch!.
    The battery still looks good: It works fine since 1993!. Unfortunately it could not be replaced directly.
    Thank you for all guys!
