Nutube Mini Major
Discussion in 'Building the Classics' started by JKrauland, May 3, 2018.
  1. JKrauland
    JKrauland New Member
    Oct 17, 2016
    28
    Hey everyone,
    So I've been checking these nutubes out and I had the idea to use them to make a really compact mini major. I've always wanted a major but couldnt afford a legit one, not to mention it's way too powerful. Do you think this is possible? Also if anyone knows where to find a schematic for a mini major i'd be eternally grateful. I'm not too hip to amp building, I mostly do luthiery stuff so I'm not quite savvy enough to convert the original marshall schematic to what I'm talking about.
    Thanks a bunch
  2. ampmadscientist
    11,220
    5,257
    Left Coast
    From what I understand, Nutubes are extremely microphonic.
    The Nutube requires a switching power supply (DC to DC converter) to run the florescent "filament?"
    For a person who does not build amplifiers, it could be a formidable challenge.
    But don't forget, Philo T. Farnsworth.
    He knew nothing whatsoever about electronics, and 20 years later he invented television. He simply "did it," despite that such a thing was widely regarded as impossible - he never gave up.
    Drawing inspiration from Philo, (and I hope you will) be sure that determination and perseverance make the impossible possible.
  3. Copperheadroads
    Copperheadroads Active Member
    Oct 6, 2012
    115
    29
    On a Rock in the North Atlantic
    Microphonic ? as a pickup winder Send the Nutubes to me & I will wax pot them for you .
  4. ampmadscientist
    11,220
    5,257
    Left Coast
    You will need more than wax to fix that issue.
    Check out the microphonics test at 14:14.
    Remember that the nutube has a maximum gain of: 5.
  5. Copperheadroads
    Oct 6, 2012
    115
    29
    I've have fixed dozens of microphonic Gibson pickups without potting them .you Just need to know how to do it . Fenders on the other hand should be potted .
  6. ampmadscientist
    11,220
    5,257
    Left Coast
    Dude,
    this thing starts ringing just by laying your hand on the test bench....:agreed:
    It would take 3X nu tube sections to equal the gain of 1X 12AX7.
    But nu tube has voltage limit which is less than 1/3 of vacuum tube.
    In other words: replacing preamp tube with nu tubes would be pretty challenging. I'm not saying impossible.
    Copperheadroads likes this.
  7. printer
    printer Member
    Sep 30, 2017
    86
    91
    Pencil tubes have been around for a while.
    I looked at a schematic of the Major and the preamp section is easy enough to do, no need to use different tubes than the original. The power tubes and the output transformer will be where you have to decide what you want. You don't want the power so I am guessing a lower wattage tube than the KT88's would be fine. How much power do you want. Also the big question, how much do you want to spend on it? Also what is it you desire in the amp, what makes you want it. Making a mini version will have trade offs. Good to know what makes it special to you.
  8. ampmadscientist
    11,220
    5,257
    Left Coast
    Those are peanut tubes.
    I used to have a little pocket radio which used those. It ran off a 90 volt battery.
  9. printer
    printer Member
    Sep 30, 2017
    86
    91
    Peanut tubes, pencil tubes, potato tomato.
    Thought about building a smaller version of the amp. There was a 100W done here before, less than that is possible but the main attribute of the amp was that it was a clean machine. For someone not versed in electronics it might take someone else to do all the dirty work of coming up with a layout and bill of materials.
