NPD: Boss LS-2
Discussion in 'The Tone Zone' started by SkyMonkey, Dec 2, 2019.
  1. SkyMonkey
    1,394
    1,540
    England
    Well I succumbed to Cyber Monday and just ordered a 'Mint' BOSS LS-2 Line Switcher off Reverb! £57!
    The pedalboard is nearing the core 5 pedals I think I need for a basic rig.
    The LS-2 will switch between a BD-2 and the DSL preamp in loop A, and an MT-2 in loop B going directly into the DSL return (bypassing the preamp).
    Next I need to find a BOSS RV-6 and we're off!
    Though this might be close enough to start thinking about getting a RockBoard Tres 3.1 and start plumbing it all in!
  2. LCW
    LCW Well-Known Member
    Jan 18, 2017
    308
    354
    Ha - I just picked up an LS-2 off Reverb last week. $60 mint. It's a useful tool, even though I don't have any burning use for it at the moment. But it offers so many possibilities to get creative.
    You will dig the RV-6. I have one of those also and it's a legit reverb pedal.
  3. MickeyJ
    MickeyJ Active Member
    Nov 11, 2019
    304
    210
    i found the boss ls-2 to be a tone sucker. A significant chunk of highs seemed to vanish, was it the buffer? I've tried others from time to time, same thing.
    Have no experience rv-6, however i had both rv-5 and rv-3, the rv-3 was on another planet, much better. a lot less floor noise, a lot more ' real' sounding reverb.
    I still have rv-3.
    i have an rv-2 as well, but it's quite hissy, I prefer this pedal to rv-5 also.
    stringtree and SkyMonkey like this.
  4. SkyMonkey
    1,394
    1,540
    England
    RV-2 is mono? Have looked at RV-3 which is a cross between reverb and delay. Both those are really quite rare in the UK.
    I think the RV-6 is better suited to my needs than the RV-5 (stereo and shimmer). Also the +Delay setting will get me by until I decide if I need a dedicated delay.
    Tone-suck is something I have seen on YT and read in other reviews. Some say they suck, some say they don't.
    If it is a sucker then an EQ may be the solution. But it is tailor made for what I need to separate out the MT-2 for direct injection into the FX return only.
    Will post my experience when it gets here in a few days.
  5. MickeyJ
    Nov 11, 2019
    304
    210
    The problem I have is that if the features all exhibit the same ' thing' I don't like, then the features mean nothing.
    The rv-5 is thin sounding too.
    the rv-3 is very lush, fat with very low floor noise, I consider it a gem.
    the rv-2 is lush as well ( not as lush as the rv-3), but you really can hear the low bit rate in action, quite hissy.
    if you decide to get a dedicated delay you're going to get hit hard with recommendations from people. My favorite dig delay is the dd-2, it does have a low bit rate also, but the repeats have some decay to them which sounds really good.
    SkyMonkey likes this.
  6. stringtree
    stringtree Well-Known Member
    May 21, 2016
    908
    1,568
    Mitchell Pearrow and SkyMonkey like this.
  7. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,589
    1,675
    Södertälje, Sweden
    I love my LS2. It's just a utility pedal but It just made everything easier... use it in the loop, to switch in whatever your lead fx are and use the loop level to get transparent level boost for your solos, all at one stomp
    Happy NPD
    J
  8. LCW
    Jan 18, 2017
    308
    354
    Going to get rid of the LS-2. It's a tone sucker (in my setup).
  9. SkyMonkey
    1,394
    1,540
    England
    Sorry to hear that @LCW.
    Not received my one yet. Should get here by the weekend for me to test it out.
    LCW and stringtree like this.
  10. SkyMonkey
    1,394
    1,540
    England
    So the LS-2 has arrived, and is indeed in mint condition.
    Other things to note are the lack of an info sticker on the base. I did notice this in the advert, but only after buying it.
    Some other BOSS pedals from the same seller were the same, leading me to think they are factory seconds.
    No sticker means no serial number!
    But it looks kosher otherwise. No box, but instruction sheet included.
    Mitchell Pearrow and stringtree like this.
  11. SkyMonkey
    1,394
    1,540
    England
    LS-2 all works OK with the NS-2 too.
    Quite a volume mismatch between loop A (BD-2>amp preamp) and loop B (MT-2>FX return) being quieter.
    Can dial in parity with the LS-2 loop levels, A @ 2 O'clock & B @ 9 O'clock.
    So far only tried a mechanical test really, with the VS65R at very quiet levels.
    Not really noticing any tone-suck yet either.
    All good. But the LS-2 and NS-2 don't play well with MXR flat right-angle patches. Jack sockets too close together.
  12. Sustainium
    Sustainium Well-Known Member
    Oct 4, 2019
    230
    442
    Lapeer, Michigan
    All good. But the LS-2 and NS-2 don't play well with MXR flat right-angle patches. Jack sockets too close together.[/QUOTE]
    These work well.
  13. Mitchell Pearrow
    8,798
    13,427
    Cheers to your new pedal brother.
    Mitch
    SkyMonkey and stringtree like this.
  14. SkyMonkey
    1,394
    1,540
    England
    You all probably know this already, but I just realised you can use the LS-2 on it's own as an in-the-front booster, or as an effects loop volume attenuator!
    I was looking online for something like the JHS Little Black Amp Box Volume Attenuator when I remembered the LS-2 has a level knob for each loop.
    You can hook up the LS-2 in effects loop without anything plugged into the A/B loops. Just amp Send>input/output>amp RETURN, and set the levels for each loop to give 2 different levels of switchable volume attenuation. Works a treat.
    At 12 O'clock the knobs are unity level. So if used out the front they should be able to be used as 2 different levels of boost too!
    Not tried this one yet though. I might be a lot of boost!
    I was going to sell it, but this might make it a keeper!
    stringtree and Jon C like this.
  15. johan.b
    Feb 21, 2015
    1,589
    1,675
    Södertälje, Sweden
    ... that's what I tried to tell you above...
    J
  16. SkyMonkey
    1,394
    1,540
    England
    Sorry. I missed your meaning.
    I just didn't realise it would work at all with nothing plugged into the loops. Just straight through the INPUT to OUTPUT!
