Noise problem
Discussion in 'The Workbench' started by Jeru78, Jan 14, 2020.
  1. Jeru78
    Jeru78 New Member
    Jan 13, 2020
    7
    Hi
    I'm playing a Marshall JCM 800 Lead Series Model 2210.
    It has been making this enoying noise for a while.
    It occurs (only) when I open the master volume button.
    No guitar plugged in.
    Can anyone tell what's causing this noise en how to get rid of it?
    I tried using different speaker cabinets, changing cables, different wall outlets, ... and the problem remains.
    Thanks!
  2. ricksdisconnected
    Aug 11, 2019
    1,012
    1,560
  3. marshalltsl
    marshalltsl Well-Known Member
    Apr 6, 2012
    304
    339
    Catalonia
    :welcome: to the Forum.
    Best of luck fixing your amp. I'm sure some amplifier technician MF members will help you.
  4. tce63
    Aug 6, 2018
    1,118
    2,760
    Sweden
    :welcome: to the forum, a great place
  5. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,020
    5,059
    Montreal
    Let me first say that I am by no stretch of the imagination an amp tech and never will be. Anything I say here has been learned from this site and in fact I don't know how well I've learned it !!! lol
    In any event some questions:
    Do you have experience changing tubes? This an important question in order to avoid killing yourself.:wow:
    Do you have a spare, in good order pre amp tube available for testing purposes? More than likely a 12AX7.
    I'll stop here awaiting reinforcements and your answers.
    BP
    p.s. and :welcome:
    neikeel likes this.
  6. ampmadscientist
    14,866
    8,725
    Plug a guitar cable between send and return then re-test.
    Plug a footswitch into the FS jack, and retest. Operate the footswitch did the probem go away?
  7. Jeru78
    Jeru78 New Member
    Jan 13, 2020
    7
    Hi, just tried it. The noise problem remains.
    tce63 likes this.
  8. Jeru78
    Jeru78 New Member
    Jan 13, 2020
    7
    Hi, I never changed a tube. But I guess I will manage watching some Youtube examples ... (hope I don't die ... haha ) ... I think I know someone who has some spare parts (tubes), who's coming over next week. I'll let you know what he brought before starting experimenting.
    Thankx!
    tce63 likes this.
  9. BanditPanda
    Oct 19, 2015
    5,020
    5,059
    Montreal
    Good show. Just remember the " death" part is factual as there are enough stored volts in there to do that.
    BP
    tce63 likes this.
  10. ampmadscientist
    14,866
    8,725
    Yes it can be a noisy preamp tube.
    instinctfx likes this.
  11. neikeel
    3,654
    2,076
    Sounds like a dodgy preamp tube to me as suggested above (ECC83/12AX7 or 7025). Suggest you buy a new one from a reputable source and replace each one in turn with the new one until the problem goes.
    You do not have to remove the amp from the chassis, just the back panel. You should turn the amp off between each change (I confess I tend to just use standby when rolling but if you are new to this turn it off each time.
    Please report back when you have done this.
  12. Seanxk
    Seanxk Active Member
    May 14, 2018
    155
    98
    I've just fixed the very same noise problem today, it was the stand by switch on an 800.
    Power off and disconnected from wall, conservatively spray deoxit cleaner in the tiny holes at the back of the switch ( power switch too while you're there ), toggle a few times and try.
    tce63, neikeel and marshalltsl like this.
  13. Jeru78
    Jeru78 New Member
    Jan 13, 2020
    7
    Thanks for the advice so far guys !! ... I got a shoe box full of old (but never used) Fender and Ruby Tubes (they were in my dad's house ...) Also including two Fender 7025-12AX7A. Will these do the job? (I must admit I'm a bit scared now hearing about the danger for stored volt)
    I already removed the electronic panel from the head.
    tce63 likes this.
  14. ampmadscientist
    14,866
    8,725
    Don't be afraid.
    If you die, you will be immortalized in the Marshall Amp Forum Hall of Fame :hbang:, recognized for extraordinary bravery in the face of Amplifier noise.
    Good luck.
    BanditPanda likes this.
  15. Jeru78
    Jeru78 New Member
    Jan 13, 2020
    7
    I already removed the electronic panel from the head. Can I use the Fender 7025-12AX7A to test? So I have to make sure I dont touch the Capacitors? How long do they stay charged?
  16. Jeru78
    Jeru78 New Member
    Jan 13, 2020
    7
  17. neikeel
    3,654
    2,076
    If you only remove the back panel to tube juggle there is nothing to shock you.
    yes, assuming your 7025 is good then swap away.
    Peter McAteer likes this.
  18. Jeru78
    Jeru78 New Member
    Jan 13, 2020
    7
    It was indeed a broken tube.
    Thanks!
