No Specifications Of Products - Why?
Discussion in 'Amplified Parts' started by ampmadscientist, Mar 19, 2018.
  1. ampmadscientist
    16,640
    10,538
    [​IMG] Here is a switch I can across. CED/amplified parts/ tubes and more is telling us ( ) about the dimensions and rating of the switch...
  2. ampmadscientist
    16,640
    10,538
    It's a 20mm hole and the rating is 250 volt 10 amp.
    The keyway slot on this hole is 2mm...
    I don't install non rated parts in amplifiers....
  3. mickeydg5
    mickeydg5 Well-Known Member
    24,080
    11,070
    I wish they would list the manufacturer and its part number.
  4. ampmadscientist
    16,640
    10,538
    Nearly 100% of all parts vendors: will list the manufacturer and part number...with the specification sheet.
    That's the whole point : disclose all the important information.
    CED does not listen to what the customers are asking for. This has been a major problem.
    I don't have the information I need to make a good purchasing decision.
    Every time I go to buy a part from CED, it's another game of: "where's Waldo?"
  5. mickeydg5
    24,080
    11,070
    I do not buy parts that often but I know the frustration. If I need something they have or have cheaper without any specifications i try to find it elsewhere. Sometimes you can see the manufacturer name in pictures. If I cannot find specifications then I move on to something that gives the information required.
  6. ampmadscientist
    16,640
    10,538
    Manufacturer: Schurter
    Ohms Selector part number 0033.4032
    voltage Selector Part Number 0033.4019
    Mounting Hole: 20mm (key slot is 2 mm additional if used)
    Rating: 10 amp, 250 Volt
    Data Sheet:
    http://mt.rsdelivers.com/product/sc...tary-switch-3pst-10-ul-csa-a-63-iec-a/8650133
  7. mickeydg5
    24,080
    11,070
    I did mean I try to find the specifications elsewhere. I usually would buy multiple items from whomever had all the goods at the lower total.
    That is a nice looking component and easy to deal with if installing or replacing.
