NGD: '87 2558 Silver Jubilee Combo!
Discussion in 'Marshall Amps' started by marco_giampa23, Mar 26, 2020 at 4:44 AM.
  1. marco_giampa23
    marco_giampa23 Active Member
    Feb 11, 2020
    223
    183
    My first original jubilee, sounds amazing. Bit rough on the outside so will need to clean and reglue some tolex, any recommendations of easy to find adhesives for tolex and how to clean the tolex?
    Here is my main question, taking the chassis in and out to me on this amp is an insane struggle, anyone have any tips? Found it very difficult to support the chassis in the perfect spot while attempting to screw it in.
    Here are some pics, I have got a lot of pictures of the inside but apparantly my phones quality is too large, what do you guys use on the forum to link lots of photos, dropbox, imgur?
  2. J Saw
    J Saw Well-Known Member
    Apr 26, 2017
    424
    675
    VA
    Turn cab upside down and get two bolts in caddy corner, then upright for the other two?
    edit: Happy NAD!
  3. marco_giampa23
    Feb 11, 2020
    223
    183
    Ended up putting it upside down on a chair and screwing it in from the bottom.
    Mitchell Pearrow and Wenander like this.
  4. Wenander
    Wenander Active Member
    Aug 10, 2015
    177
    185
    Sweden
    We want to hear it =)
  5. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    1,686
    1,614
    Shakedown Street
    Very cool , including the Marshall branded Vintage 30's ( my favorite speaker )
  6. Musicmaniac
    Musicmaniac Active Member
    Apr 10, 2013
    133
    153
    Cool congrats!
  7. headcrash
    headcrash Active Member
    Jun 19, 2015
    134
    184
    Awesome, me too likey likey these Marshall G12 Vintage speakers :dude:
  8. CROWEMAG
    CROWEMAG Active Member
    May 22, 2018
    136
    78
  9. Kinkless Tetrode
    Aug 17, 2017
    1,104
    1,369
    An auto parts store should have headliner/carpet glue.
    The problem there is that its probably in a spray can. But you could spray it in a disposable cup and then brush it on.
    Another thing an auto parts store should have is weather stripping adhesive in a tube. Easier to apply. Pick up a roll of blue shop towels while your there. Get some black gloves while there too. They should know what you mean.
    Also pickup a bottle of tire dressing to condition the tolex when done. Spray it on the shop towel and then wipe it, so it doesn't get where you don't want it.
    A quart of denatured alcohol or acetone should be at your local hardware store for a cleaner pre adhesive. Put it on on a towel to wipe it rather than poring it directly on the surface your cleaning. You will use this where you plan on applying adhesive or for cleaning adhesive off of where you don't want it. A pencil erasure can also be used to clean off excess glue. Maybe test it in an inconspicuous spot first, if you want to use it on the outer surface. Make sure no acetone or denatured alcohol gets on any guitars! Make sure you have gloves on and are in a well ventilated area.
    Just some soapy water for most of the outer surface after gluing. Once again a car wash soap might be better because it won't dry out the vinyl.
    Another good exterior tolex cleaner is actually WD40 wiped on followed by wiping it off. But you don't want any oils near where you want to glue.
  10. Jethro Rocker
    7,592
    8,262
    Good for you! Got the good one!! Fantastic amp, congrats!!
  11. marco_giampa23
    Feb 11, 2020
    223
    183
    dont have a proper recording setup so ill throw togethor an unlisted Youtube video on my phone today
  12. marco_giampa23
    Feb 11, 2020
    223
    183
    Thanks for the help, probably try some vinyl glues at an auto store or check some old threads
  13. Force235
    Force235 Well-Known Member
    Nov 15, 2012
    965
    467
    MA
  14. marco_giampa23
    Feb 11, 2020
    223
    183
  15. ampmadscientist
    16,545
    10,455
    Contact cement can glue tolex.
    You apply a thin coat to both halves, and let it almost dry. Then you mate the parts together.
    Turning the amp upside down is probably the best way to deal with the chassis. Also makes installing tubes easier.
  16. marco_giampa23
    Feb 11, 2020
    223
    183
    Here is a quick little video I threw together on my phone.
    Im running my stock 2002 Gibson LP studio straight in the front in 50watt mode
    fairly loud, definitely not bedroom volume
    here are my settings
    Input gain - 6
    Lead master - 10
    Master - 1.5
    Treble - 5.1
    Middle - 6.7
    Bass - 7
    Presence - 5.6
  17. marco_giampa23
    Feb 11, 2020
    223
    183
    will definitely try get some contact cement, there are afew small nicks in inconspicuous places that ill try first before i do the very noticable ones
  18. Wenander
    Aug 10, 2015
    177
    185
    Sweden
    Nice .... Loud huh?!?
  19. marco_giampa23
    Feb 11, 2020
    223
    183
    Its the perfect volumme for me, if its getting late i can lower the output master an chuck it in 25w mode. Its at the perfect volume right before its moving too much air and you can feel your eardrums moving (that feeling when you hear a loud clean signal) , definitely can get loud if I need it to though
    Wenander and Mitchell Pearrow like this.
  20. headcrash
    Jun 19, 2015
    134
    184
    These look similar to my settings on my 500W mini head clone, although for band practise master volume is at around 11 a.m.
