New tubes rebiased sounds like crap. Please help
Discussion in 'The Workbench' started by 12AX7, Feb 4, 2020.
  1. ampmadscientist
    18,187
    12,196
    100ma would make the tubes last forever but it would sound like doo doo.
    They might set it that way when it's under warranty, just to make sure the tubes won't wear out.
    Well yes eurotubes is correct at 180 ma.
    With 180 reading, the actual plate current is around 40 ma per tube or 160ma plate all 4 tubes.
    The other 20 ma is being used by preamp tubes, screen grids, and slight leakage of filter caps etc.
    12AX7 likes this.
  2. mickeydg5
    mickeydg5 Well-Known Member
    24,657
    11,592
    100mA is incorrect. Do not follow this instruction. There is a lack of information. This amplifier can operate with 6L6/5881.
    12AX7 likes this.
  3. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,135
    429
    Netherlands
    Dont listen to them. Try 90mA and judge for yourself.
  4. ampmadscientist
    18,187
    12,196
    You can run it low 90-100ma if you want but there's a lot of crossover distortion.
  5. mickeydg5
    24,657
    11,592
    My biggest point was that the instruction indicating 100mA did not specify the power tube type.
    6L6/5881 may be nice at 25mA per power tube but I would not care for 6CA7/EL34 at that idle.
    I also do not think it mentioned pulling preamp tubes or how much current the rest of amplifier will draw.
    If you subtract that from the 100 then its way low for 4 power tubes.
  6. J E H
    J E H Active Member
    Apr 4, 2018
    249
    99
    AGAIN, tubes are a pain in the ass.
  7. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,038
    722
    Really? They treat me just fine.
  8. Gunner64
    Nov 16, 2013
    6,041
    7,708
    Midwest, USA
    You must be sitting in the wrong place..:D
