New Marshall CODE digital amp series
Discussion in 'Marshall Amps' started by Moony, Jan 20, 2016.
  1. colkai
    colkai New Member
    Sep 26, 2016
    13
    13
    Since the firmware update, my Code isn't recognised as a USB/Midi device. :(
    Tried logging off the PC, rebooting the Code a few times, nothing.
  2. Antmax
    Antmax Well-Known Member
    Aug 7, 2015
    463
    262
    California
    You could try a factory reset. Otherwise I don't know. So far it seems Marshall haven't really gotten the computer/electronics thing down yet.
    I got to use the Spider V recently and the interface and updating is very well done on those amps. Puts Marshall to shame. Has low latency ASIO streaming drivers but no bluetooth though.
  3. Antmax
    Aug 7, 2015
    463
    262
    California
    It might be that particular USB port on your computer needs to be reset. Sometimes they go wrong. If your using windows then the only way to do it is to actually unpower the computer. If it's a desktop you have to turn it off at the PSU or unplug it. If its a notebook unplug and disconnect the battery for a few seconds.
    That removes residual power from the motherboard so it will reset the USB ports.
    Sometimes if something isn't plugged in cleanly the USB port will be registered as dodgy by the motherboard itself and disabled from working properly until reset.
    If that doesn't work you can try a factory reset and unplug the amp. Just in case something similar happened on the amp side.
    Otherwise I don't really know. You will have to try Marshall support.
    stw500 likes this.
  4. stw500
    stw500 Member
    May 27, 2016
    80
    15
    I found some spikes I bought once for my big stereo speakers. I put them underneath the code 50 and both my wife and I found it sounding slightly but noticable warmer then before.
  5. Antmax
    Aug 7, 2015
    463
    262
    California
    Cool, I might have to try that. Mine sits on a side table which reverberates quite a lot.
  6. Jam81
    Jam81 Member
    Jul 20, 2016
    39
    16
    Ever since updating the firmware, when I record in Audicity via USB, there is a lag in the recording, this does not happen when I use the headphone line out to record but only with USB, any idea why this is happening and how I can fix this?
    Thanks!
  7. stw500
    stw500 Member
    May 27, 2016
    80
    15
    You are the second one experiencing problems after updating. Perhaps it is wise to wait for the next firmware update. The qm of marshall seems to lack.
  8. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    2,945
    1,274
    Have these amps been discontinued yet?
  9. jstich
    jstich Active Member
    Dec 18, 2016
    134
    65
    Musicians friend has a date of May 29 when they'll have the 100 watter in stock.
    Deep Purple fan likes this.
  10. Arc Anjil
    Arc Anjil Member
    Dec 26, 2012
    61
    28
    Florida
    I can't tell if I'm up to date. My Gateway says:
    AmpFirmware 1.3
    AmpDSP 1.1
    AmpBluetooth 3.1
    MarshallGateway 1.4.1
    Where does Marshall tell us what the latest and greatest is?
  11. Jethro Rocker
    5,052
    3,352
    Not sure. Download the latest firmware from Marshall and see what it says. It won't allow you to overwrite with old software, obviously.
  12. Sybex7254
    Sybex7254 New Member
    Jul 17, 2015
    4
    2
    Only a year and a half late...great job!
  13. Antmax
    Aug 7, 2015
    463
    262
    California
    The code really needs low latency ASIO drivers for streaming like most interfaces and other modeling amos with USB hookups.
    That eay you can use DAW effects modeling plugins in your effects chain and still record without lag. Currently the code seems to just hsve a basic line out through usb.
    Its a shame because it does reduce a lot of the flexibility digital offers and other modelers make use of.
  14. Harrison Liddle
    Harrison Liddle New Member
    Jan 9, 2017
    2
    I can't get the USB to record in Cubase could you assist?
  15. Harrison Liddle
    Jan 9, 2017
    2
    I cannot get my code to record through USB in cubase. Can you help?
  16. Quoman7
    Quoman7 New Member
    May 6, 2016
    26
    11
    Does anybody know how to download presets from Marshall downloads, to gateway on my phone?
  17. Plectrum
    Plectrum Active Member
    May 11, 2016
    237
    159
    UK
    Pretty obvious really as long as you have a My Marshall account. Copy the preset to My Library. The go to My Gateway. Scroll down and you'll see all your My Library presets at the bottom. You can drag the one to want to where ever you want in the list list of 100 presets. The next time your phone's Gateway syncs with the server, you'll have the preset on your phone.
  18. Quoman7
    Quoman7 New Member
    May 6, 2016
    26
    11
    Was obvious, must have been post xmas hangover I didn;t see my gateway! lol Cheers for the heads up! :facepalm:
  19. BowerR64
    Nov 23, 2014
    2,945
    1,274
    Sometimes if you uninstall the USB device then it will refind it and reinstall the drivers. Ive had different USB ports refind items you may also try to uninstall the USB item (like threw device manager you right click then uninstall that device) Before you update it so then it refinds the amp again with its new version and reinstalls the device drivers for the "new amp"
    You also may have to uninstall the program on windows and reinstall it. Sometimes the programs/edit utility what ever it is isnt just the program but it has the device drivers in with it. Uninstall everything related to the code amp and start over.
    You may have to do both.
    Try a different PC with a fresh install of any programs the amp uses to connect to the computer with the new firmware amp see if it still has lag and see if it connects.
    Ide bet the PC sees the amp but cant communicate with it because the new firmware communicates different then it did with the last firmware. If that makes any sense?
  20. Antmax
    Aug 7, 2015
    463
    262
    California
    If your usb port on your PC doesnt recognize a device. Sometimes its because the plug shorted out and the motherboard needs to be reset to reinitialize the port.
    A simple shutdown and restart wont fix it. The incident was registered at a lower level before windows a bit like a car diagnostic code.
    Just like the car you have to disconnect power completely to reset the usb so it will attempt to recognize the device again. This means turning off the PSU or unplugging a desktop from AC mains. On a notebook you have to unplug and temporarily disengage the battery for a few seconds.
    Reconnecting the battery/AC resets the motherboards internal failsafes and it will attempt to work with that usb device again.
    It has happened to me a few times mostly with cameras and phones that refuse to work after fumbling with micro usb ports in the dark.
