New Jet City Amelia 50 Watt Head.
Discussion in 'Other Amps' started by chromeboy, Jan 1, 2017.
  1. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,628
    2,549
    My complaint about the JCA50H was that it was way to gainy, even on the crunch channel it was way to heavy for me.
    Im wanting a more classic clean/edge of break up tone but still want something that has the 80s classic rock overdrive.
    Even if channel one cant do the edge of breakup thing if its clean an OD pedal can be used atleast.
    This guy got some decent tones from it i though
    stringtree likes this.
  2. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,633
    4,192
    Austin TX
    FWIW, I'm playing vintage output pickups and Channel 1 will start to breakup a bit at around 3/4 volume. I'm using a compressor and I've never cranked it much beyond that as I am *trying* to keep it clean :) With hot pickups I'm sure you could get more out of it.
  3. stringtree
    stringtree Well-Known Member
    May 21, 2016
    908
    1,571
    No ones experienced any problems with the effects loop as in the video below.......
    When the pedal in the loop is activated, it bumps up the volume. He tried 2 different pedals, same result.
    Or is this just user error on his part by not adjusting the volume of said 2 pedals...
  4. Trident
    Trident Well-Known Member
    Mar 8, 2018
    923
    1,132
    Paradise in FLORIDA
    Are these amps cathode or need to be biased?
    This amp does have my attention....
  5. johnfv
    Sep 29, 2010
    5,633
    4,192
    Austin TX
    IMHO, they are a bit misleading about this. There is a bias trim pot inside and it should be adjusted as needed. They default to a rather cold bias and the amp still sounds pretty damn good regardless. Put your favorite tubes and bias properly and *truly* enjoy.
  6. Trident
    Mar 8, 2018
    923
    1,132
    Paradise in FLORIDA
    Might have to dig a bit deeper and try one out!
    They look and from youtubes they sound pretty good...
    Thanks for the info..
  7. BowerR64
    Nov 23, 2014
    4,628
    2,549
    So who the hell designed it? I thought it was a rehash of the Soldano with the 2 channels rolled back a little so they wernt so gainy and an improved effects loop?
    This is the demo that made me want it, if you watch the video IMO its a different amp then what i have. Mine doesnt appear to have any mods either.
    In the first part of the video hes getting a classic break up with the ch1 volume at noon, it sounds very marshally in this video
    wntbtw likes this.
  8. BowerR64
    Nov 23, 2014
    4,628
    2,549
    Dang i think maybe i got the wrong model.
    I got the Earnhardt, to much uhhh OVERDRIVE!
  9. Tobias Klare
    Tobias Klare New Member
    Nov 28, 2019
    6
    Hello Johnfv! Where is this bias trim pot? Is it, where the tubes are, or do I have to take the whole “thing“ out?
    I own this amp, but can't find much information.
    Bye the way...hello forum, I'm new here.
  10. ampmadscientist
    14,957
    8,785
    Welcome to the forum Tobias :cheers:.
  11. South Park
    1,259
    939
    Greetings from cal your amp is a slo 100 clone . It has a bias pot for the drivers. The pre amp tubes are fixed bias . The one stage is a cold clipper.
  12. Tobias Klare
    Nov 28, 2019
    6
    Hello Southpark!
    THX for your answer. I try to repeat, what I understand, because my English is not that good.
    1. I don't have to do anything with the bias if we talk about preamp tubes?
    2. But I have to do something for the other tubes?
    I don't understand the sentence with "the cold clipper"
  13. South Park
    1,259
    939
    The bias on the preamp tubes are good. The power tubes get re bias if you replace them . The bias is set low on one stage of the preamp tubes that is what is called cold clipping .
  14. Tobias Klare
    Nov 28, 2019
    6
    And where is that bias pot for the power tubes? And what do you mean with "stage"?
  15. South Park
    1,259
    939
    The bias pot is on the circuit board. The guitar signal goes from one preamp tube to another in a chain then goes to the power tubes. Each stage does something different . Like tone shaping and gain
  16. Tobias Klare
    Nov 28, 2019
    6
    Okay. Thank you. Now I have better picture of the whole thing.
    Do you know, which reading, would be needed for the power section? Of course I know, that there is not only one reading.
  17. South Park
    1,259
    939
    Look up info on slo 100 . Mike Soldano built that amp is a clone. The power section is the same as the 2204
  18. johnfv
    Sep 29, 2010
    5,633
    4,192
    Austin TX
    As others have mentioned:
    Welcome to the forum!
    The bias trim pot is inside on the circuit board.
    I happen to have a picture from when I was doing some mods, the trim pot is circled in yellow:
    Tobias Klare likes this.
  19. Tobias Klare
    Nov 28, 2019
    6
    Thank you very much, Johnfv. And what Reading should the bias have? So to say "between which borders"?
  20. Tobias Klare
    Nov 28, 2019
    6
    Thank you, Marshallforum. I managed to adjust the bias new.
    Great to have infos from people who know some things.
