New interesting item on the bench
Discussion in 'The Workbench' started by chuckharmonjr, Jun 10, 2019.
  1. Goldguitarguy
    Goldguitarguy Active Member
    Mar 29, 2019
    131
    28
    My wall voltage at the switch is 123vac so that would be where in lies the numbers difference then.
    Sorry OP for the hijack
  2. ampmadscientist
    14,957
    8,785
    60 ma for one tube or both tubes?
    I think about 37 ma per tube at least...
    What you are reading is plate + screen current not plate current alone.
  3. Goldguitarguy
    Mar 29, 2019
    131
    28
    I measured the voltage from pin 3 to ground. Is that both the plate and screen voltages? So I would subtract the screen voltage from that number or how does that work? And yes I believe it is for both tubes, I just googled how to bias a hot rod Deville and watched a tube Depot video on YouTube. I'm still learning the the basic techie stuff.
  4. ampmadscientist
    14,957
    8,785
    The voltage on pin 3 of the output tube is the plate voltage.
    The voltage on pin 4 is the screen voltage.
  5. mickeydg5
    23,316
    10,400
    60mV/mA is for both tubes, 6L6GC, at the 1 ohm cathode resistor as per the schematic you are referring.
    The 499VDC is due to 120-123VAC from the wall versus 117VAC.
    Goldguitarguy likes this.
  6. Goldguitarguy
    Mar 29, 2019
    131
    28
    Definitely wasn't something on my radar as a factor ever...Thanks for the lesson Mickey
    mickeydg5 likes this.
  7. mickeydg5
    23,316
    10,400
    You are welcome. :yesway::)
    Chuck, what is going on? :hmm:
  8. chuckharmonjr
    Mar 26, 2010
    8,818
    4,296
    I have parts on order to rebuild the bias supply circuit. Also had a few traces that looked suspect.
