New dsl100h tube choice and biasing
Discussion in 'The Workbench' started by glprich, Jan 6, 2020.
  1. glprich
    glprich Member
    Mar 1, 2015
    43
    St louis Mo usa
    Agree..wrong
  2. glprich
    glprich Member
    Mar 1, 2015
    43
    St louis Mo usa
    Ok once the math is done and you have your mA value,( just for an example lets say its 36mA) on the dsl with the three pin test points, is it balanced at 36mA or 72 mA ( center to left pin, and center to right pin)since it a pair of tubes per side?
  3. mickeydg5
    mickeydg5 Well-Known Member
    24,657
    11,593
    The DSL100H has two tubes on each side of the push-pull power amplifier. The left pin measures on side and right pin the other. You should measure about 72mV(mA), which would be about 36mV(mA) per tube, at each pin to center pin.
