New Dsl
Discussion in 'Marshall Amps' started by hpharley90, Sep 13, 2017.
  1. baconjerky
    baconjerky Member
    Feb 24, 2017
    34
    32
    The price of that 1w with it being made in Asia now is right where it should be. They're gonna do very well in particular
  2. renips
    renips Well-Known Member
    Nov 15, 2010
    634
    379
    Homestead, Florida
    The 10" speaker in the 20cr sets it apart from most other offerings in the smaller combo market because if the 10" speaker. The amp has probably had the circuit designed to maximize the 10" speaker. The 20 hr allows for the pairing to 1x12,2x12 and 4x12 cabs. I am sure people will use it with 4x10 cabs. This is going to successful.
    riffermadness and BanditPanda like this.
  3. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    929
    542
    Södertälje, Sweden
    Dual and i assume footswitchable masters are a welcome addition on the 100 watter.
    j
  4. JohnH
    JohnH Well-Known Member
    May 31, 2008
    2,841
    741
    Wilton NSW
    I think this looks like a good line of products for Marshall. There's a proper amp there for anyone who wants a real one of any size, all referenced to the very well regarded DSL line and classic style. I hope they sound as good as they should and do well, to allow Marshall to keep developing.
  5. Kinkless Tetrode
    Kinkless Tetrode Active Member
    Aug 17, 2017
    162
    117
    Yes, that should have been a no brainer. On the DSL15H all that was needed was to switch in a gain bleed to ground through a 150k resistor then Lead 2 turns into Lead 1. There was even a place for the resistor on the board. Putting in a switch to switch green clean to green crunch would have been just as easy.
    These might be a different preamp design though. Only three ECC83s? Did they replace a couple of gain stages with diode clipping or something?
    But a loop will be welcome to many in that market segment. That was a deal breaker for many for the DSL15.
  6. slagg
    slagg Active Member
    Apr 7, 2012
    415
    148
    Cheezeland Wi
    Agree:dude:
    baconjerky likes this.
  7. Jethro Rocker
    5,021
    3,315
    I still find it very strnge that these don't appear anywhere else. Something fishy?
    4Horseman and Micky like this.
  8. Jethro Rocker
    5,021
    3,315
    But the old ones had gain and volume for each channel as well.
  9. Bloodrock
    Bloodrock Well-Known Member
    Aug 12, 2010
    1,873
    1,591
    Ft.WorthTX
    So the 20w only has 3 12ax7's? Hopefully that's an indication that the ultra channel will be more like ultra 1 and not the awful ultra 2 like the 15h! So now the question, will classic gain be based on the crunch channel? If so these 20w heads will be great!
  10. Msharky67
    Msharky67 Well-Known Member
    Mar 12, 2012
    754
    269
    Queensbury ,NY
    I thought the first reissues where perfect. Why change them again. My original DSL50 is going to be worth nothing now since the supply of DSL's are so wide. Tell's me Marshall is plum sunk out of ideas. My next amp won't be a DSL for sure! Now a mini JCM800 with reverb ,FX loop low wattage then you got me talking. I guess that will never happen. :2c:
    JCarno and hpharley90 like this.
  11. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    2,089
    1,141
    Montreal
    You know what Sharky ? I think it will happen a mini JCM800 with reverb ,FX loop low wattage.
    JCarno and JAC like this.
  12. AlanH
    AlanH Active Member
    Jul 2, 2017
    184
    147
    UK
    While the description looks the same has anybody else clocked the two extra knobs on the DSL40CR photo (13 knobs vs 11 on the DSL40C)??
    ken361 likes this.
  13. Angus Rhoads
    Angus Rhoads Well-Known Member
    May 10, 2017
    415
    435
    SF Bay Area, California
    Master Volume 1 & 2 like the JVM line - check out the photo of the DSL100HR, it's much clearer and expands better. Can't read what's on the two extra buttons, though I assume one is to switch between 1 & 2, but what does the other one do?
  14. Jethro Rocker
    5,021
    3,315
    Ah now I see it. Also 2 MV as per JVM. Nice. But why only on here? What about Marshall.com? I don't get it.
  15. Vintagemod
    Vintagemod New Member
    Sep 14, 2017
    6
    4
    Its embargoed and Marshall have not announced yet. Not fishy just google crawling links that sites have put up too early. Happens all the time.
  16. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    291
    89
    I think in Lead 1 mode there's supposed to be a 10k resistor in series with the cathode bypass cap.
    This lowers the gain even more with the 150k resistor installed in R82, no? Or does this minimize switching noise instead?
  17. Kinkless Tetrode
    Aug 17, 2017
    162
    117
    I don't recall.
    On edit: Try a 100k instead of a 150k, it reduces gain more below 12:00 and makes the amp respond better to guitar volume knob riding, but you still have more gain than you will ever need by just cranking the gain up to about 3:00.
  18. JCMDOUG
    JCMDOUG Active Member
    Mar 1, 2015
    322
    196
    where its cold
    I will Buy the 100HR for sure. For live playing two master volumes works the best for me.
    I have four amps that have it, JVMs and my 900s. Its the one of the reasons I have stayed away from the 800s no effects loop unless its a reissue is the other reason.
    Sickriverlespaul likes this.
  19. marshallmellowed
    Jun 26, 2009
    2,103
    1,341
    Probably released by Marshall as a marketing probe. Hear the complaints before making the amps. :hmm:
    Jethro Rocker likes this.
  20. BrentD
    BrentD Active Member
    Jan 27, 2012
    555
    212
    Lansing, MI
    The pictures look like they have the right elephant vinyl to match older amps. I also see rivets on the corner protectors instead of the screws on the current line.
    It's small potatoes but it did drive me nuts!
    I'd love to see side handles on the 40CR.
    ken361 likes this.
