New BOSS 200 Series pedals
Discussion in 'The Tone Zone' started by Kutt, Jun 13, 2019 at 9:49 AM.
Tags:
  1. Kutt
    Kutt Well-Known Member
    May 27, 2010
    794
    843
    Massachusetts, USA
    Looks like they are coming in September. Modulation, Delay, Dirt, and EQ.
    https://www.boss.info/us/categories/stompboxes/200_series/
  2. SkyMonkey
    278
    299
    Sheffield, UK
    What's with the new MIDI connection?
  3. Kutt
    May 27, 2010
    794
    843
    Massachusetts, USA
    Available for pre-order.
    WellBurnTheSky likes this.
  4. blue
    blue Active Member
    Feb 22, 2011
    214
    126
    Ireland
    The EQ looks interesting
  5. MonstersOfTheMidway
    May 1, 2008
    4,659
    2,008
    I, too, think the MIDI connection is interesting. I wonder if the cable Boss designed features a 5-pin connector on the other side (I think I read something about using an adapter for the cable, but I'm not sure what they're talking about). I'm also wondering if there's any lag/latency issues when switching.
    The two pair of input and output are also an interesting feature. I noted how the overdrive/distortion/dirt pedal does not have the same two pair input and output ports.
    I wonder if these pedals are going to be buffered like the some of the stompbox/floor pedals in the past.
    Very interesting group of pedals that I'm definitely going to check out.
    Thanks for posting/sharing.
    Kutt likes this.
  6. SkyMonkey
    278
    299
    Sheffield, UK
    The MIDI connector is for a BOSS TRS/MIDI.
    "The BMIDI-5-35 is a special cable with an angled 3.5 mm TRS connector on one end and a standard 5-pin male MIDI connector on the other, allowing you to connect to external MIDI-equipped devices such as pedals, effects switchers, and MIDI foot controllers. Made from rugged, high-quality materials, BOSS cables deliver performance you can count on."
    https://www.boss.info/global/products/bmidi-5-35/
  7. JohnH
    JohnH Well-Known Member
    May 31, 2008
    3,430
    1,324
    Wilton NSW
    Exciting news, provided they are built Boss-tough and also sound excellent. They seem to have everything covered....
    ...except for the one thing that I'd really need, being a reverb.
    jimmyjames likes this.
  8. jimmyjames
    jimmyjames Well-Known Member
    Jun 15, 2014
    1,407
    1,378
    West Oz
    RV-6 is decent, unless you want Strymon levels
  9. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    447
    260
    NJ
    it's like they took families of effects pedals and put them into one unit. the is pretty low considering what you get.
    Did you see the SY-300 ($700)? It sounds amazing compared to other guitar synths.
  10. mickeydg5
    20,290
    8,101
    You know what works better? The old SE-70. :)
  11. Micky
    Apr 29, 2010
    19,972
    15,923
    Vermont
    I really don't like the form factor.
    I prefer the built-like-a-tank older models...
