New Attenuator Day
Discussion in 'The Tone Zone' started by FutureProf88, Jul 12, 2017.
  1. FutureProf88
    FutureProf88 Well-Known Member
    Oct 2, 2012
    1,510
    554
    St. Louis metro area
    Got my Hotplate today. I must say I'm really impressed. I had a Rivera, which had better features than the Hotplate (balanced line out, switchable impedance) but I think at low levels of attenuation the Hotplate is a bit more transparent. There also isn't a huge jump between attenuated and non attenuated volume levels.
    Full disclosure I've only tested it with my C5, but if anyone is interested, my findings were:
    At -4 db there was a slight volume reduction and no change in tone or feel. At -8 there was a noticeable loss of high end. Using the bright switch brought it back and brought the feel of the amp back to near non-attenuated response. The tone and feel remained pretty intact at -12 as long as the bright switch was used. At -16 to -infinity (fully adjustable control) the feel of the amp was greatly diminished. The deep switch really changed the tonality of the C5, but it actually made it sound like a much bigger amp. I couldn't hear a difference with the bulbs engaged or not.
    I'd say that this is a great tool to protect a speaker cabinet from a 100 watt amp or to bring a big amp down closer to club friendly volumes. It will not satisfy someone who wants to attenuate an amp down to a conversational level for something like late night practice.
    Barfly and MarshallDog like this.
  2. Jakeboy
    Jakeboy Active Member
    Dec 15, 2010
    401
    168
    Missouri
    Quality attenuators are my friends.....
    tone seaker likes this.
  3. ampmadscientist
    5,750
    2,125
    The better method is adjustable magnet speakers.
    These do not kill the high frequency at lower loudness settings.
    Another helpful method is to change the amp output to triode, to lower the efficiency.
    BanditPanda likes this.
  4. el_bastardo
    el_bastardo Well-Known Member
    Apr 26, 2017
    1,767
    1,648
    That's pretty much the M.O. for any attenuator. Great for knocking a few db off, but a huge compromise for bringing a giant amp down to whisper levels.
    FutureProf88 likes this.
  5. FutureProf88
    Oct 2, 2012
    1,510
    554
    I'm not using it for lower loudness settings. I'm bringing it down to a 50 watt or 25 watt level so I can run it with a single 1960BX.
  6. tone seaker
    tone seaker Well-Known Member
    Jan 20, 2011
    2,811
    2,577
    Where the Rock Rolls Hard and the Blues Rains Down
    I have been using "The Ultimate Attenuator" for 13 years with my 100 watt Marshall Super and fender's to bring them down to gigable levels and protect the speakers. You can hear it in the link bellow in my signiture "My Music" with my Marshall cranked :)
  7. Barfly
    Barfly Well-Known Member
    May 6, 2012
    989
    791
    NYC, NY
    Clips or it sounds like an AM radio.
    SG~GUY, flyinguitars and FutureProf88 like this.
  8. Len
    Len Well-Known Member
    Sep 13, 2009
    724
    305
    To bring a loud amp to conversation level without killing the tone you usually need a re-amper (Unleash, Ultimate, Power Station, etc).
  9. ampmadscientist
    5,750
    2,125
    Wrong.
    I certainly do not need any transistor amp attached to a Marshall.
  10. ampmadscientist
    5,750
    2,125
    Change to triode output wiring instead.
  11. FutureProf88
    Oct 2, 2012
    1,510
    554
    Never been a fan of triode modded amps. I have considered that but I like the snap too much. The attenuator works better for me. I fail to understand why you're so against the idea of using power attenuators. For ultra low volume practice they aren't the best solution but they work well for the applications that they're really designed for. Also, reamping is another tried and true technique and something like the Power Station (which uses a tube power amp) is pretty much the EVH recording setup.
    Here is a short (14 sec) clip from our gig Saturday. I was running a Germino HR100 through a BX cabinet. Amp settings were: Presence 1, Bass 3, Mids 6, Treble 6, Bright Volume 6.5, Normal Volume 2, Hotplate to -8, bulbs off and bright switch and deep switch both off. You're seeing our bass player here as this video was taken by one of his friends and he wrote this song. We haven't recorded it yet but it's called "Spilled Drinks and Bath Towels."
  12. tone seaker
    Jan 20, 2011
    2,811
    2,577
    Your loss my gain, it sounds amazing. My clips prove it :)
    Len likes this.
  13. MonstersOfTheMidway
    May 1, 2008
    4,192
    1,499
    I don't use attenuators, so please correct me if I'm wrong, but it's my understanding that most attenuators are designed to be connect between the amplifier's speaker output and the cabinet's speaker input.
    Question: what happens if the attenuator fails? Is there a fail safe or some other feature/circuit that protects the amplifier is the attenuator fails?
    I understand attenuators get extremely hot due to the amount of energy they are taking in from the amplifier (most designs have some kind of cooling system such as a fan to help dissipate heat). But if an attenuator should fail for whatever reason, what are some features that protect the amplifier? For example, if the attenuator fails, do some attenuators have a built-in feature that allows the signal to "bypass" the attenuator altogether and be sent to the cabinet as if the attenuator was not there? I know attenuator designs vary from manufactuer, so any info would be appreciated.
  14. FutureProf88
    Oct 2, 2012
    1,510
    554
    Not that I'm aware of. It's the same deal as if a speaker fails. No failsafe there. Just get an attenuator that's rated much higher than your amp. The Hotplate is 185w max. A Rockcrusher is 150w max. Weber's are marked as to their maximum wattage.
  15. el_bastardo
    Apr 26, 2017
    1,767
    1,648
    Attenuators are shockingly simple devices, so failure is pretty rare.
    I've broken my Weber Mass 200 twice. Don't ask. Both times my fault. Both times the attenuator still passed signal, it just didn't attenuate.
    Not all attenuators are the same, but the Weber stuff seems to be the simplest and most foolproof. Some of them use a tiny speaker motor with no cone for "swamp load" in the event of some kind of catastrophic failure. Mine's been to hell and back and keeps working and sounding great. As long as you use an attenuator that's rated roughly twice what you're putting through it, they'll be fine forever.
  16. tone seaker
    Jan 20, 2011
    2,811
    2,577
    My Ultimate Attenuator is rated at 200 watts and have giged it more than 1000-4 hour gigs for 13 years. One of the features I like about the UA is it has dual foot switchable volume controls that are smooth turn like a volume knob not clicking down DB levels like most others so you can get exactly the level you want not to high or low like a hot plate style. The dual volume allows you to have one set for rythm and the other set louder for lead. :)
    Len likes this.
  17. JohnH
    JohnH Well-Known Member
    May 31, 2008
    2,841
    741
    Wilton NSW
    My view is that if your favourite amp is a modern design with an effective master volume, then an attenuator is not needed at rehearsal or gig volume. There are fine tones to be found at lower than max volume. On these, some attenuation can sometimes help when you get the amp back home and need to do some low-volume practice. For this, l favour a very simple fixed attenuator to knock the power down by a factor of 5 to 10 (-7 to -10db). Its a simple box, one plug in, one plug out, cheap and reliable. its not really about cranking such an amp at whisper volumes, but just getting it up off the noise floor and into the range where the MV sounds best. These moderate levels of attenuation have very little effect on tone.
    But I can understand how a more complex attenuator could be useful if your tone is that of a NMV amp at melt-down volume.
  18. tone seaker
    Jan 20, 2011
    2,811
    2,577
    The only way I can make a master volume amp not sound like a buzz saw is to crank the master volume to 7-8 pushing the power tubes and controling the actual volume with the pre amp volume. :)
  19. Len
    Sep 13, 2009
    724
    305
    Ok, please show me a bunch of posts indicating that goos sounding high levels of attenuation can be achieved with a passive attenuators. There are many posts by others (including me) that increasing the attenuation of a passive attenuator beyond a few dB impacts tone too much.
  20. tone seaker
    Jan 20, 2011
    2,811
    2,577
    once the speakers stop being pushed you lose some tone :)
