Need Help With Mosfet
Discussion in 'Amplified Parts' started by Exojam, Jul 3, 2018.
  1. Exojam
    Exojam Well-Known Member
    May 31, 2017
    659
    414
    Below is a picture of two mosfets from a Blackstar HT100. The “924” numbers are date codes and I found information on the number “SMK830”.
    The first link shows about 4 variations and the second shows information from Mouser.
    So my question is if any can let me know which one I should be ordering.
    Thanks so much in advance.
    https://alltransistors.com/search.php?search=Smk830
    Mouser:
    https://www.mouser.com/Search/Refine.aspx?Keyword=IRF830
  2. ampmadscientist
    16,667
    10,557
    These componetes are exc
    These components are exclusively made in China.
    You will probably order it from Hong Kong.
  3. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,097
    390
    Netherlands
    IRF830 should work fine. Double check the pinout out.
    Exojam likes this.
  4. tschrama
    May 15, 2010
    1,097
    390
    Netherlands
    To be sure, post a larger portion of the schemo.. I !think! these mosfets are used as source follower to drive the power tubes ...?
  5. tschrama
    May 15, 2010
    1,097
    390
    Netherlands
  6. ampmadscientist
    16,667
    10,557
  7. Exojam
    May 31, 2017
    659
    414
    That it does! It was purchased as a broken amp and that is what I found. Whoever worked on it took no pride in their work or did not know what the hell they were doing. They hammered the bias section of the board so I ordered a lot of stuff from Mouser to hopefully get the amp working.
    Larger section of schematic is above.
  8. Exojam
    May 31, 2017
    659
    414
    Also, thank you for the help.
  9. hazmat7719
    hazmat7719 Well-Known Member
    May 26, 2013
    622
    258
    Maryland
    Ebay has them for $6.90 each.
  10. Exojam
    May 31, 2017
    659
    414
    Ordered the ones from Mouser earlier this evening but thank you.
