Need help, original JCM 800 LS??????
Discussion in 'The Workbench' started by Exojam, Aug 22, 2019.
  1. Exojam
    Exojam Well-Known Member
    May 31, 2017
    635
    403
    I was hoping I could get some help from all of the smart Marshall folks here.
    I was checking out a 1985 Marshall JCM 800 Lead Series and would like to know if you folks could tell me if anything looks as if it was modified or changed out of this amp.
    The one thing I did notice, it looks to me like the filter caps (I believe) have dried out due to all the white residue on the unit along with the rust on them. And I was also wondering about the green and orange wires coming from I believe the OT wired to the resistors. If I recall when I built my 50 Plexi clone this is where you would be measuring to set the bias. My question on that is, do they look like the wiring has been changed or is it original.
    Thank you very much in advance.
  2. ampmadscientist
    15,401
    9,271
    It's been messed with.
    neikeel likes this.
  3. Exojam
    May 31, 2017
    635
    403
    More info please.
  4. Gunner64
    Nov 16, 2013
    5,444
    6,565
    Midwest, USA
    Shouldn't an 85 have drakes?.my 87 did.one fuse holder's siliconed in, guess they lost the nut or stripped it...and look at all the shrink tubing where the wires have been spliced...definitely been messed with. I'd buy it for $500, but if they're asking the going rate I'd look elsewhere.
    MarshallDog likes this.
  5. ampmadscientist
    15,401
    9,271
    The amp was taken apart, for what reason I cannot know.
    It's kind of sloppy...
    Gunner64 likes this.
  6. Exojam
    May 31, 2017
    635
    403
    Thank you both.
    Keep them coming.
    They are asking around 1,100.
  7. Gunner64
    Nov 16, 2013
    5,444
    6,565
    Midwest, USA
    Imo No way. Better ones out there for that.
    Exojam likes this.
  8. MarshallDog
    Nov 28, 2010
    12,786
    12,486
    Taintville
    One or both of those trannys could have been changed because they are not Drakes and all the wires are zip tied together. I believe the wires were originally tired together with small black rubber rings which leads me to the conclusion they were cut off to allow a transformer change out.
    neikeel and Gunner64 like this.
  9. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    747
    423
    Here’s a pic of mine, made 4 months after OP’s, rubber rings and Drake iron. The factory wiring is considerably neater.
  10. MarshallDog
    Nov 28, 2010
    12,786
    12,486
    Taintville
    FYI, the more I look at those pics, the PT and OT both look shinier than the choke. I believe they are not original.
    If it still sounds good its maybe worth 600.00 - 800.00 bucks if everything else is in good shape IMO!
    Exojam likes this.
  11. ampmadscientist
    15,401
    9,271
    I don't think you should pay that much, needs a bunch of work looks like...
    Exojam likes this.
  12. ampmadscientist
    15,401
    9,271
    Exojam and neikeel like this.
  13. Exojam
    May 31, 2017
    635
    403
    Thank you all for helping me save my money!!!
    Unfortunately I would not be able to play the amp before purchase so I will pass.
    Also Chris, thank you for pics that show how it should look so hopefully I will not have ask this question again.
