Ok, just put new preamp tubes. It was working fine before and after the preamp tube change. I didn't use dexoit but used a quick drying elect contact cleaner - sprayed on all preamp tubes inserted and removed a couple times. when I take amp off stand by I hear some static and then a hum starts coming from the speakers and its a hum that gets a little louder and stays steady. I can tell it's not a good sound. I cleaned speaker input cables and yet it's still doing it. I cleaned the footswtich cable and the plug. I cleaned the instrument cable and plug. Thoughts on what this could be? maybe a power tube going out?? I did not change the power amp tubes.
But was the hum there before you changed preamp tubes? You can swap the new ones out one at a time with an old one and see if one tube has more hum than the others.
Plug your guitar straight into the return of the loop. If the hum is not there then you know it is the preamp section. If it is it is in the Poweramp section. Being a 100 watt version. Pull the 2 inside EL34’s. If you have a 16 ohm cab set amp impedance on 8, if 8 ohm cad set amp on 4. These are easy trouble shooting techniques. Roll all tubes. Use chopstick test. Use different guitar, cord, speaker cab, cord. Disconnect Reverb tank etc... Take notes. David
Right. Lately it seems people ask for help then do not respond to the most simple logical troubleshooting techniques. D
My apologies on late response. Will reply shortly on pugging into effect loop , then if swapping preamp tubes solves the humm issue
Plugged into return. No hum. Sounds pretty cool like this. Plugged in footswitch and amp seemed to get a boost of volume. Unplugged reverb last nite but no effect on hum. Will try rolling the preamp tubes.
Replaced tube 5, phase inverter and all is well. Thanks for the help and education!!! I mixed up the pi tube with others. Any good way to find out which one is the phase inverter?
Well i think it was the V1 and V5 tubes. Right now running 12ax7 in V1 and V5 and this gainy monster is like a racehorse crashing into the starting gate... wanting to be turned loose. lawd it screams and has a little squeel to it if I don't play something. sounds like RAWK!
Awesome! You'll always find extra tubes are always handy! Unfortunately, I've found a few new ones bought...crap right out of the box. It happens.
