Need A Jmp 2203 Gut Shot
Discussion in 'The Workbench' started by valvehead, Apr 15, 2019.
  1. valvehead
    valvehead New Member
    Jun 1, 2011
    13
    ok, ive searched the web for an hour. I need a specific pic. Maybe someone here can help. Amp needs to be a 78-80 JMP 2203........i need a good pic of the Impedance switch inside--with the speaker jacks and wiring . Trying to wire my 80' up now. The switch needs to be the turning style--NOT the press in plug type. Anyone??
  2. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    7,514
    4,363
    My amp is modded the resistor & white cap on the purple wire is a resonance mod. It also has the rotary impedance installed. This was a few years ago.
    This is what it looks like now after a Metro loop install.
  3. valvehead
    Jun 1, 2011
    13
    Thanks..that switch is different ....hard to see..which wire is going from switch to jacks + ? Or is there one ? Where is the + wire coming from thats on the jack ? I know brown is ground...purple is fb.....blk / yel/ green is 4/8/16
  4. charveldan
    Jan 31, 2010
    7,514
    4,363
    On mine purple is + [via R/C] & brown is -
    But like i said mine has been modified.
