Narrow gold piping wanted for '64 style JTM45 build
Discussion in 'Building the Classics' started by growler, Apr 1, 2020.
  1. growler
    growler New Member
    Apr 1, 2020
    10
    5
    I'm looking for some gold piping for a 1964 style JTM45 build to fit between the black and white sections on the front panel. It's not the easily available 'gold string in clear plastic' piping, it's either like the 'T' section shiny gold plastic 'strip' as is used on the front an AC30 but narrower, or, gold coloured shiny plastic tadpole piping. I believe both were used. Also, it's not the round piping that's used on the cabinet shoulders. If you know of a supplier, or particularly if you have some to sell me then please PM me direct. Many thanks.
  2. MarshallDog
    Nov 28, 2010
    13,891
    14,338
    Taintville
    Try Mojotone, they might have it??
  3. neikeel
    4,216
    2,672
    Don't think Mojo have it.
    Last I got for a resto was from Robert at Valvestorm
  4. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,547
    1,652
    I got some solid brass piping with right dimensions no plastic around but it looks good. I used it for my latest Clubman built.
    Got it from Ray in the US
    plexi
  5. MarshallDog
    Nov 28, 2010
    13,891
    14,338
    Taintville
    Try this website for Mojotone, they have a few different styles plus the small rope piping in gold. Not sure what else would be needed??
    https://www.mojotone.com/Piping_x#/
  6. pleximaster
    Feb 6, 2012
    1,547
    1,652
    For the thin gold string Vox wire has best gold color!
    neikeel likes this.
  7. Matthews Guitars
    1,799
    2,380
    Here's how to make your own.
    Get some gold tinsel piping. You can get it from mojotone.
    Get some ultra clear 1/8" heat shrink tubing. (3m makes it)
    Take a length of it and carefully cut the plastic so you can extract the gold tinsel string.
    Thread the tinsel thru the heat shrink tubing. Use heat to shrink it.
    You now have gold string piping that looks far more authentic than what you can normally find. Install it in the groove as normal,
    and it can be retained better with the aid of some glue.
  8. neikeel
    4,216
    2,672
    @MarshallDog and @Matthews Guitars
    The op is not talking about gold string, he is talking quite specifically about the plastic beading with round lip that was used on early JTM45s (split front and first all black heads in 65) across the front of the head cabs.
    Mojo do not do it. The Vox equivalent is wider and has bigger tongue.
    Nearest stuff if you cannot get the plastic stuff is bass fretwire (the stuff Pleximaster was sent).
    Compare the top 3 here with the bottom one:
  9. pleximaster
    Feb 6, 2012
    1,547
    1,652
    That was the kind I meant in my first post... :)
    Original thin metal and plastic surround ... UNADJUSTEDNONRAW_thumb_2948.jpg
    The struff from Ray. Solid aluminium with gold tint
    And its the same stuff used on the Offsets
  10. growler
    growler New Member
    Apr 1, 2020
    10
    5
    Thanks guys, so I'm looking for wide, brass (?) bass guitar fretwire? Who supplies it? Who is Ray? Many thanks!
  11. pleximaster
    Feb 6, 2012
    1,547
    1,652
  12. growler
    growler New Member
    Apr 1, 2020
    10
    5
    Thanks, I've been in touch with Ray, he seems a very helpful, knowledgeable guy.
  13. Matthews Guitars
    1,799
    2,380
    That looks pretty much exactly like what's on my '74 Superlead, that I asked about a while back. Right down to the hollow construction.
    It's aluminum, apparently, with a gold toned plastic coating. At least that's what's on my '74.
    As of now I'm beginning to question if my head cabinet might not be from much earlier. It seems like its trim details would be correct for pre 1970.
    Well, I know there's something funny about it because the back panel that came with it is for a 50 watt amp. But the headshell is a vented 100 watt type.
    I'm sure that I know a company that would be able to duplicate it from a pristine sample but minimum order quantities would probably be in thousands of feet.
    Brass bass fretwire? I didn't know there was such a thing. I'd expect it to wear away too quickly .
    But you could get bass fretwire from Stewart-MacDonald or Dunlop (and other guitar supply companies) and for an extra fee have a shop gold plate it for you. However, the tang of the fretwire isn't very long. You basically could not install it over tolex as you'd have almost zero tang engagement in the wood underneath.
  14. growler
    growler New Member
    Apr 1, 2020
    10
    5
    Dohh. This JTM45 build has been kicking around as a half started project for so long I forgot that I bought what I believe to be the correct, original stuff off a guy many years ago. It even has grip wedges on the piping tail to make it stay in the groove. See photos attached. DSCN1723.JPG DSCN1725.JPG
    pleximaster and neikeel like this.
  15. ampmadscientist
    17,860
    11,898
    https://www.tubesandmore.com/products/piping-marshall-gold-thin
    Piping - Marshall, Gold, Thin
    Sold by the foot
    Click to zoom in
    [​IMG][​IMG]
    Customer Images:
    No Images yet! Submit a product image below!
    SKU: S-GP002
    Item ID: 004082
    Price: $2.50
    In stock
    Sold by the foot
    Quantity
    Type
    Piping
    Genuine Marshall™ thin gold piping. Sold per foot. Please note that because piping needs to be cut, we cannot accept any returns on this item
    View Product Measurements
  16. neikeel
    4,216
    2,672
    AMS - this is the gold tadpole that you staple to the edge of the gearbox, not the front trim. I apologise if I did not make myself clear to the ‘reader’in my post above about the difference in gold piping and front panel trim.
    The post Immediately above yours looks like the OP actually has the dead on correct stuff so it is all good!!
