NAD SV20H
Discussion in 'Marshall Amps' started by pedecamp, Oct 14, 2019.
  1. pedecamp
    14,504
    11,426
    Notice the little JHS volume box on top, that in the loop has made this all possible, I can get the tones I want at home volumes and they sound good, I'm using the 20 watt mode, no need for the 5 watt mode since I have the JHS, both modes sound good though. So a couple observations and a couple things I tried, jumping the channels is the way to go, plugging into each channel individually was either too fat or too thin, so I tried 2 ways of jumpering and got good tones all around, bottom inputs provide lower volume and gain and top inputs more. I find the sweet spot for me is both channels on 7, I get edge of breakup and dig in for crunch. The normal channel adds the amount of bass to your tone, the higher you turn it up the bassier your tone, the high channel adds gain, the higher you turn up the gainier it gets, 7 on both channels is perfect for me, I can play Zep and ACDC all day long. I settled on jumpering the high channel bottom input to the normal channel top input, the reason being I plug into the top input of the high channel with my Gibsons and plug into the bottom input of the normal channel with my Strat, this is what sounded best for these guitars. The loop works well, it doesnt cut volume when turned on its very transparent and no loud pops when turning on/off unbuffered pedals, I have the JHS volume box and an LPB1 boost pedal for lead volume boost in it, works well. Currently I've been playing it through my G12T75 2x12 cab, sounds good so I havent tried anything else, I will break out a pair of greenbacks at some point to try. The stock Marshall tubes sound good too I might just leave them alone, no hurry to try other tubes. For higher gain I have a pedal board with various ODs for varying levels of gain, they all sound good, currently on the board - GE7 for low gain, RAT for medium gain, ZW OD for high gain. I have about 2.5 hours on the amp at this point and have been happy so far with what I'm getting out of it, it could be a keeper! One thing though, its got me wondering how a 1959 Super Lead compares, at the new SV20H price I could easily afford a used 1959. What the SV20H has going for it though is it sounds good, is smaller and light weight, and has a good loop, those are all major pluses. Yup I've got 45 days to think about it, I might even order up a 1959 to compare side by side! So that's my initial review. :yesway:
  2. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,867
    6,575
    Montreal
    ahahahahah------ Yippeeeeee !
    Now I'll take the time to read your post lol
    BP
    Happy New Amp Day lol
  3. pedecamp
    14,504
    11,426
    Something I forgot to mention, I want to dig up my old band mates and take this amp for a spin in a band setting to really see what it can do. :yesway:
  4. BanditPanda
    Oct 19, 2015
    5,867
    6,575
    Montreal
    Dude if you can get an SLP for the same price as the SV then do it.
    It's one of the best amps on the planet.
    BP
  5. marshallmellowed
    Jun 26, 2009
    3,676
    4,394
    I had thought about picking one of these up to try, and to compare to my bigger 4 holers. But now, after reading all the posts about still needing volume boxes or attenuators, I've kind of backed off on the idea. I can play my bigger amps just fine, with a little attenuation, so other than the smaller size (which doesn't matter to me), I'm not seeing much of an advantage. Anyone here have both the SV20 and either a 1987x, JTM45, or 1959? Would be cool to hear their take.
    Mitchell Pearrow, netlocal and tce63 like this.
  6. BanditPanda
    Oct 19, 2015
    5,867
    6,575
    Montreal
    Good 'cause it does look like you're trying to corner the market of outstanding Marshall amps!!:dude:
    BP
  7. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,746
    4,129
    Springfield, Ohio
    Can you get controlled feedback at low volume with that box in the loop?
  8. pedecamp
    14,504
    11,426
    Yeah it doesnt seem to make sense for you, I'm still trying to figure out if it makes sense for me, so far so good. :yesway:
    Somebody here did have an SV20 and a 1987x, they got rid of the 1987x!
  9. pedecamp
    14,504
    11,426
    Absolutely
    Are you using an attenuator with yours?
  10. Michael Roe
    Mar 25, 2017
    1,746
    4,129
    Springfield, Ohio
    HAPPY NEW AMP DAY!!! It finally arrived!
  11. pedecamp
    14,504
    11,426
    I think what I like about the SV20 over the SC20 is its a little different flavor of tone than my 2204, gives me variety. The SC20 was pretty spot on to my 2204, theres just a tiny bit more mids showing through in the SV20 and the quality of gain seems a bit smoother. I gotta do an actual comparison between the SV20 and 2204. :yesway:
  12. JeffMcLeod
    JeffMcLeod Well-Known Member
    Sep 28, 2017
    1,482
    2,080
    Clips or it never happened...
    :coffee:
  13. Michael Roe
    Mar 25, 2017
    1,746
    4,129
    Springfield, Ohio
    I find the SV to be more versatile than the 800. Maybe not live but for recording there are just so many good tones you can pull out of it. For lead playing, there is no question, the SV rules them all. If I was a better lead player then I would make much more use out of it :)
    Try a Tung-Sol Gold in V1 for some extra cream.
  14. Michael Roe
    Mar 25, 2017
    1,746
    4,129
    Springfield, Ohio
    I was going to say that!
    Ok, I will.
    Yeah man, clips or you just posted fake pics!
    Clip it up buddy!!! LOL!!!
  15. tce63
    Aug 6, 2018
    1,532
    3,980
    Sweden
    Finally, Congrats :applause:
  16. scozz
    scozz Well-Known Member
    Jul 20, 2008
    3,241
    7,345
    Congrats @pedecamp,.......:thumb: you waited a long time for this amp, (even longer than you had to), :D Enjoy in hood health!
  17. Michael Roe
    Mar 25, 2017
    1,746
    4,129
    Springfield, Ohio
    I'm putting my money on @pedecamp wanting a Mini Jubilee next. It will probably arrive around the end of 2020.
  18. clutch71
    clutch71 Well-Known Member
    Sep 26, 2007
    1,591
    1,034
    Columbus, Ohio
    I was curious if a volume type control in the loop would work, good to know. I've played the SC20 and liked it so I would really like to try the SV20. Let us know how what you think of Greenbacks. Congrats on the amp.
    Mitchell Pearrow and pedecamp like this.
  19. Kutt
    Kutt Well-Known Member
    May 27, 2010
    1,098
    1,516
    Massachusetts, USA
    What a handsome amp! Those two amps can do it all.
    I got that same pedal years ago, then modified it with a treadle. Looks like this. :)
    Mitchell Pearrow, pedecamp and tce63 like this.
  20. scozz
    Jul 20, 2008
    3,241
    7,345
    Yeah if he orders it today!
