NAD - Peavey 6505 + Combo
Discussion in 'Other Amps' started by Jethro Rocker, Sep 19, 2019.
  1. Jethro Rocker
    7,067
    6,930
    I had one of these years ago and traded it on the 5153 mini head. Wished I would have kept it, gets nice floor chunk at lower levels. Given the size of venues we usually play, I kinda missed it. Found a good used one today!
    Only issue is static for the first 20 secs after releasing standby. Once it warms up it's fine. Changed some pre tubes. Haven't tried power tubes yet. As long as it sounds good and works fine I don't really care. Killer gain.
  2. South Park
    South Park Active Member
    340
    205
    Peavey made some good stuff. All high gain amps have some static. Rock on
  3. Jethro Rocker
    7,067
    6,930
    No I realize it has high gain hiss. This is static. No source, volume zero. Seemed to be worse when tapping amp top thus the micro tube thought. But it's not that. I might try a conditioned power supply. Or power tubes.
    Oddly when I removed the chassis, it did not do anything amiss when I rapped on the top edge of chassis. But it did once mounted again.
    I think it's once it warms up it's fine.
  4. South Park
    340
    205
    You are getting oscillation in the gain stage.it is the same thing as microphone feed back.you have some much gain it is leaking in to the grids and getting amped up.a lot of times something needs to be grounded
  5. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,062
    999
    20 seconds hiss then no more is some kinda tube issue imho
    Don't blame it on the high gain circuit, that's not how it works
    OP: you keeping it stock or speaker swapping?
    Jethro Rocker likes this.
  6. Jethro Rocker
    7,067
    6,930
    No I have NO guitar plugged in. Volume at Zero. Gain at zero. Noise starts as soon as standby switched off. It is static sort of like a dirty pot. It is not. I cleaned them just in case. It is not a microphonic tube as far as I can tell.
    I will look at whether it is coming from pre or power amp.
  7. Jethro Rocker
    7,067
    6,930
    Not sure yet. I might try a V30 in there.
  8. Gunner64
    Nov 16, 2013
    4,840
    5,393
    Midwest, USA
    Dirty tube socket perhaps?
  9. Jethro Rocker
    7,067
    6,930
    Yes worth looking at too. I'll play today
  10. Jethro Rocker
    7,067
    6,930
    Changed power tubes. It's silent now with volumes down. Perfect!
  11. solarburnDSL50
    Aug 8, 2008
    15,505
    8,761
    Wetville
    Congratz!
    Power tubes get noisy/static too. Good call bud.
    What speaker is in it?
    Deep Purple fan likes this.
  12. Jethro Rocker
    7,067
    6,930
    Yep.
    It's the stock Sheffield. Sounds ok so far. I'll play when I get a chance. Try a V30 to brighten it up some. Or what have you. T75. It's a heavy large bugger for a 1x12. Nice addition to the fleet though. Something different.
  13. solarburnDSL50
    Aug 8, 2008
    15,505
    8,761
    Wetville
    Cool. Was wondering if it was a Sheffield. Id rock it stock and see too.
    yeah man they are not grab and go combos by any means. Love the tones though.
  14. South Park
    340
    205
    Good job rock on
  15. Jethro Rocker
    7,067
    6,930
    I will!! Lookkng forward to gigging it.
  16. Deep Purple fan
    Nov 1, 2014
    2,441
    2,276
    Virginia
    Congrats on your find. Those are great amps.
    Jethro Rocker and solarburnDSL50 like this.
  17. Mitchell Pearrow
    7,687
    10,953
    Congratulations JR nice amp
    I was also going to say try power tubes, I have had a bad one on 2 occasions with the same thing you described, cool you got it figured out.
    Rock on with it bro!
    Mitch
  18. Kookaburra
    Kookaburra Member
    Jul 19, 2019
    50
    56
    Phoenix, AZ, US
    Have not played one myself, but one of the guys in Cherry Monroe used one when I saw them around 2006. It sounded killer!
    Congrats!
