Nad....57 champ clone..
Discussion in 'Other Amps' started by johan.b, Jun 12, 2019.
  1. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,426
    1,327
    Södertälje, Sweden
    I don't really like these, but I always wanted one anyway. Even thought many times about buying a kit and build one.... so a ready built kit clone came up locally at roughly half the price of a kit, so why not.
    What I don't like about them is the way they break up, but I think I have a simple solution for it.. sadly over sprayed in black, but it doesn't look too bad. Can't wait to get home and play now..
    Pics coming later..
    J
    solarburnDSL50, tce63 and MarshallDog like this.
  2. Micky
    Apr 29, 2010
    19,994
    15,944
    Vermont
    I love mine...
    tce63 likes this.
  3. Im247frogs
    Im247frogs Active Member
    Jan 31, 2012
    148
    123
    Brooklyn, Joey!
    I just got a 70's Vibro Champ, almost totally original. I'm having fun going thru it and replacing some drifted components. planning on doing a tone stack lift and a couple other things. I really don't dare even flip the power switch on my plexi in the new building I'm in. Wankers.
  4. johan.b
    Feb 21, 2015
    1,426
    1,327
    Södertälje, Sweden
    67Mopar, tce63, MarshallDog and 3 others like this.
  5. Im247frogs
    Jan 31, 2012
    148
    123
    Brooklyn, Joey!
    Yeah, I just posted this so the guys on the Telecaster forum could help me diagnose the buzzing. It seems everyone has a "dead quiet" Champ except me :(
  6. johan.b
    Feb 21, 2015
    1,426
    1,327
    Södertälje, Sweden
    Modern preamp tube and offset heater wiring... if you got one. Pop a nos tube in the first socket and try again..
    J
    tce63 likes this.
  7. Im247frogs
    Jan 31, 2012
    148
    123
    Brooklyn, Joey!
    Yep, I'm planning on rewiring the heaters w a virtual center tap. The V1 socket and tube were noisy, so I rolled the few Marshall-branded ecc83's I pulled from my plexi until I found a relatively decent one. Far from a known good tube tho. It's better but its still noisy enough that I have to dig a big further.
    tce63 likes this.
  8. Micky
    Apr 29, 2010
    19,994
    15,944
    Vermont
    Put up some gut shots if you can!
    tce63 likes this.
  9. netlocal
    netlocal Active Member
    Jan 16, 2012
    113
    179
    California
    Two Champs daisy chained, dimed, with a Tube Screamer = Fun city.:hbang:
    Rocked many a dive bar this way. And some bigger shows too. On the big stages sound guys don't get all over your ass for being too loud. They don't take up too much room in the truck either. I love these amps.
    neikeel, tce63 and jmp45 like this.
  10. johan.b
    Feb 21, 2015
    1,426
    1,327
    Södertälje, Sweden
    netlocal, tce63 and Micky like this.
  11. Im247frogs
    Jan 31, 2012
    148
    123
    Brooklyn, Joey!
    MarshallDog, netlocal and tce63 like this.
  12. johan.b
    Feb 21, 2015
    1,426
    1,327
    Södertälje, Sweden
    Speaker plug needs replacing. Not solid and giving crackling sound at high volume( mentioned above)
    And the speaker is 8 Ohm. Should be 4 Ohm.. no biggie, but loses a few watts there...
    .. and I believe, what I don't like about single end circuits when clipping is the wiggle at the cathode in an unbalanced circuit. It adds a warble to the tone I don't like.
    The 25uF is enough for the bypass as far as audio goes. But looking at it from bias point of view, I tend to prefer the rock solid fixed bias. Thinking off the bypass cap as a filter cap instead and ballparking 40mA, I'll try a 470uF. I think that'll take the warble out of the overdrive. . we'll see...I could ofcourse be full of xxxx and not having a clue..I'll get back to that.. but not tonight. ..
    J
  13. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    10,452
    8,523
    Taintville
  14. tce63
    tce63 Well-Known Member
    Aug 6, 2018
    556
    1,247
    Sweden
    MarshallDog and netlocal like this.
  15. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    1,511
    1,855
  16. MarshallDog
    Nov 28, 2010
    10,452
    8,523
    Taintville
    Doesn’t get much simpler then that!!
    tce63 likes this.
  17. Sdunn
    Sdunn New Member
    Jun 3, 2019
    28
    12
    Great looking set up! I didn't realise you could daisy chain champs in this way, seems obvious seeing it!
  18. Micky
    Apr 29, 2010
    19,994
    15,944
    Vermont
    I run the hi input of my '57 into my DSL5c.
    It is matched perfectly.
  19. johan.b
    Feb 21, 2015
    1,426
    1,327
    Södertälje, Sweden
    Yes,.... adding a 470uF across the 25uF cathode cap adds that sturdy big amp feel to the drive and eliminate that ratty-nes I didn't like.. and when needed something more sophisticated, a ge7 with mid cut down(200-800hz) gives that classic black face tone... now I just need to get a different speaker. . going to go for a celestion.. it might be heresy, but I think it'll work better for my needs..
    J
    solarburnDSL50 and tce63 like this.
  20. Im247frogs
    Jan 31, 2012
    148
    123
    Brooklyn, Joey!
    I just removed the output jack modification mine has and used the hole to do a tone stack lift switch. FRIGGIN AWESOME! Easily 2x as loud (or seems that way) and nice and crunchy. Really fun.
    tce63 likes this.
