My Bluesbreaker Build (help And Advice Wanted)
Discussion in 'The Workbench' started by DerekIsEric, Jan 27, 2019.
  1. DerekIsEric
    DerekIsEric New Member
    Jan 27, 2019
    Hi MarshallForum folks!
    Im currently building a Modified Kt66 Bluesbreaker with greenbacks etc for a university project (Pretty cool right?) but im planning on adding a reverb tank to the combo and having it integrated in the circuit (Basically a fender twin style reverb). Solid state isnt a problem for the amplification required for the reverb signal
    What would be the best way to do this?
    Has anyone done something like this before?
    Any advice on building/combining the two circuits?
    Any help is great
    S.
  2. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    7,058
    4,653
    North
    There are several guys that build amps here. I am not that far advanced .
    Several websites will schematics on this I bet
  3. ibmorjamn
    Nov 3, 2012
    7,058
    4,653
    North
  4. ampmadscientist
    14,833
    8,696
    Welcome to the forum. :cheers:
    All the information you need is contained in the Hot Rod Deluxe schematic.
    https://www.thetubestore.com/lib/thetubestore/schematics/Fender/Fender-Hot-Rod-Deluxe-Schematic.pdf
    However to use solid state / op amps you need a low voltage power supply which is usually about plus / minus 15 volts.
    Other than that, you can use the high voltage already in a tube amp, to run a tube reverb circuit.
