MXR 10 Band EQ Question??
Discussion in 'The Tone Zone' started by MarshallDog, Sep 6, 2019.
  1. MarshallDog
    Nov 28, 2010
    12,902
    12,634
    Taintville
    To start with I've never used an EQ. I dont really care to use one to shape my tone as I am good with it. My questions is can one be used to get a good volume boost without changing/altering the tone of the guitar/amp?
    If yes, can it be placed in front of the amp on the pedal board and where would it best be placed? My guess, after the tuner and wah pedal but before any OD and affect pedals??
    Thanks,
    MD
    Sustainium, CraigP and tce63 like this.
  2. Frodebro
    Frodebro Well-Known Member
    May 14, 2014
    4,143
    4,887
    Seattle
    I actually have an MXR 10 band in slot 1 on my board. Yes, it can be used to goose the front end of an amp, and you can additionally use the EQ sliders to mimic a Tube Screamer. In front of an amp that is right on the edge of breakup, it has enough gain (using the technical definition of the word, meaning voltage increase) to push the amp well into distortion by slamming the front end hard.
  3. tce63
    Aug 6, 2018
    1,210
    2,988
    Sweden
    I don´t have one, but i am thinking of getting one, today i use a Spark Boost as Clean Boost
  4. Lance Chambers
    Jun 23, 2019
    973
    1,379
    The Land That Time Forgot
    This says it all! :h5:
    MarshallDog and tce63 like this.
  5. john hammond
    Mar 5, 2019
    952
    442
    whatever you try out, check for hiss.
    theyll do all sorts of things tonally, but they all hiss.
    whenever i see someone asking about eq's , i always think ' boss pq3b,'
    its for bass , not guitar. ( works real good on guitar)
    its not a slider type, its got 4 knobs
    its parametric, and superior.
    less floor noise too.
  6. royslead
    royslead Well-Known Member
    Jan 19, 2011
    1,728
    1,122
    Wisconsin
    I have the 10 band MXR, and have only ever used it in the loop. There, it has worked extremely well for a clean boost, and for shaping tones on certain amps a bit better. I have never used one in front, but would probably use one (if I did) as last in the chain, before the input of the amp, to avoid overdriving anything else in the path. If I am using it in the loop, as a clean boost- I put it last for the same reason. Now, I'm curious, I'm going to try it in front of an amp.
  7. Frodebro
    May 14, 2014
    4,143
    4,887
    Seattle
    Try it in multiple positions. I use mine to fine-tune the signal that hits my overdrive and dirt pedals, which is also handy when switching between guitars with different outputs and tonal characteristics.
    MarshallDog, royslead and tce63 like this.
  8. The Dose of Harmony
    The Dose of Harmony Well-Known Member
    Nov 21, 2014
    444
    386
    Every rig its different, you need to figure out the position yourself !
    In my personal experience only one pedal adds no color its the Keely pro compressor thats the only pedal that keeps my tone pure .
    I own the Mxr 10 and love that pedal i only use cut around 500 hz and maybe jusr a hair to increase the signal, it adds some color you can notice that by putting everything on zero only turn it on and you will se that changes your tone.
    I feel that an eq its essential but if you dont know how to use it will work against you
  9. Derek S
    Derek S Well-Known Member
    Nov 24, 2010
    1,874
    2,708
    Rock Ridge
    I like the MXR 10 band for certain little things but the one thing I've never cared for is using it in front of the amp, much prefer it in the loop...I feel like you're changing the actual tone of the guitar itself (pickups and all) up front whereas in the loop it's more like just altering the tone of the amp (and whatever else is in the loop). But I suppose if you're experimenting with it only as a flat curve/volume boost, up front would be fine. Like someone mentioned - trial and error!
  10. pedecamp
    13,856
    10,271
    I have one, it has a separate volume and gain slider, it only works for volume boost if you have very low gain. What I think works better is the Mad Professor Underdrive, read up on it and decide if it's right for you, I got mine half price used and I think it works well. You basically set youre lead tone and volume on your amp then set your rhythm tone and volume on the Underdrive.
  11. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,554
    3,649
    Springfield, Ohio
    Exotic EP Booster...one knob...click...sounds killer! It does add a little color but, click...sounds killer!
  12. Australian
    Australian Green Beret VIP Member
    Apr 20, 2009
    17,497
    9,584
    :h5:
    tce63 likes this.
  13. anitoli
    anitoli Well-Known Member
    7,002
    8,019
    EHX Grapic Fuzz will work in both positions, has an envelope filter and an adjustable output level and fuzz gain. Works great and is quiet.
    tce63 and MarshallDog like this.
  14. mickeydg5
    23,705
    10,736
    I love shaping my tone. That is how you profile/model someone or something elses sound.
    It also adds to experience and shaping your own sound.
  15. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,365
    1,320
    Is there a decent quality knockoff available? Preferably with battery operation possible, I don't like power-supply-only pedals
    tce63 likes this.
  16. SkyMonkey
    1,613
    1,823
    England
    The cheapest I've seen in the BOSS sized pedals is a Behringer eq700 equalizer. Cheap as you like. About £20 in the UK. But cheap in all other aspects too I suspect.
    All plastic, 7 band, level slider too.
    Buyer beware.
    But, Joshua Heath Scott (JHS) seems to like their range of obvious BOSS knockoffs, and has made a sort of homage video.
    Lance Chambers and tce63 like this.
  17. MarshallDog
    Nov 28, 2010
    12,902
    12,634
    Taintville
    I need to check this pedal out!!
    tce63 likes this.
  18. MarshallDog
    Nov 28, 2010
    12,902
    12,634
    Taintville
    So I have been checking the Xotic EP Booster out. I think it may be just what Im looking for.
    Any other opinions on this pedal from user?? Im just looking for a boost pedal that does not affect tone or as little as possible.
    Michael Roe and tce63 like this.
  19. Mitchell Pearrow
    9,163
    14,170
    I run my mxr 10 band eq in front of the amp’s because that is how I run the pair of origin’s, the coloring it does is welcome in my tone shaping, the boost function seems to be more so on the Dsl40c’s than the origin’s, but I now don’t use a clean boost with it!
    Cheers Mitch
  20. MarshallDog
    Nov 28, 2010
    12,902
    12,634
    Taintville
    @Mitchell Pearrow If you had a pedal board, would you put it First or Last.
