More JVM questions
Discussion in 'Marshall Amps' started by Adrian R, Oct 16, 2019.
  1. Adrian R
    Adrian R Well-Known Member
    Jan 28, 2009
    6,285
    4,383
    Far North Chicago Burbs'
    Red channel on the DSL (OD1) has plenty of gain..no pedal needed, but then I have no solo channel from there without boosting from the loop which I do not like doing. With the 205 I can only assume that it's red channel has to have as much gain as the DSL...but then it has the separate master volume like an older 900 (21/2500).. should work fine. I will be curious to see how this stands up to my modded DSL 100 which to me is one of the best sounding Marshalls I ever heard...especially the red channel one...with the master volume up. No pedal required. I will be curious to see how it stands up to my DSL 100.
    pedecamp and Jethro Rocker like this.
  2. Jethro Rocker
    7,152
    7,139
    Yep, can do it by staying on channel 2 and using MV2. I didn't care for the fact that I wouldn't use channel 1 much so I went with the 4 channel.
  3. Lukas
    Lukas Active Member
    Apr 21, 2013
    169
    168
    Canada
    A delay is beautiful on this amp also I agree
  4. Lukas
    Lukas Active Member
    Apr 21, 2013
    169
    168
    Canada
    I find a DSL a little fizzy sounding like the JCM’s were on higher gain compared to a JVM series. Not that it’s a bad thing just a characteristic of the family line I think.
  5. pedecamp
    13,232
    9,130
    I never found the DSL fizzy, I had 2 complaints I didn't like about it the biggest being the shared EQ I could never dial in the channels so I could switch between them, the second was the tone was too scooped for my liking.
  6. jchrisf
    jchrisf Well-Known Member
    Feb 27, 2016
    335
    276
    I found this video last night and liked what I heard. It is probably the only video I've found of the JVM that I liked
  7. Adrian R
    Jan 28, 2009
    6,285
    4,383
    Common complaint with the DSL.... easily fixable with a cooler bias.
  8. Lukas
    Lukas Active Member
    Apr 21, 2013
    169
    168
    Canada
    Even with the tone shift not engaged?
  9. pedecamp
    13,232
    9,130
    Yup
  10. wmachine
    wmachine Well-Known Member
    Dec 18, 2015
    200
    270
    Ohio
    I would expect so, and will be going for that with my JS, but up front? I thought that would be better in the FX loop.
  11. G the wildman
    G the wildman Well-Known Member
    Feb 7, 2016
    441
    401
    London UK
    I just don't seem to get anything nice out of the FX I might have it too dry on the amp.
  12. thunderstruck507
    thunderstruck507 Well-Known Member
    Apr 20, 2017
    314
    353
    I have no experience with them sadly. It was a toss up between a JVM and my 2203KK at the time of purchase, but I went with the 800 because that was the core sound I really wanted.
    I have played a lot of other heads such as the JCM900, TSL, DSL, 6505+, EVH, Mesa, and Carvin. For a good metal tone they all benefited from an overdrive/boost/EQ depending on the amp. For mellower stuff they are all fine without. So it really just depends IMO what the OP is trying to get it to do.
    pedecamp and MonstersOfTheMidway like this.
  13. spacerocker
    spacerocker Well-Known Member
    Feb 6, 2009
    1,471
    834
    UK
    I think the JVM probably has more gain than any of the amps you mention! A boost/EQ etc is usually added to drive the amp harder and add more clipping ("gain") - believe me, the JVM OD channels do not need any extra gain! An EQ in the loop is always a good idea, to shape/fine tune the overall tone of the amp - but I do not believe the JVM needs one in front to "push" the amp!
    thunderstruck507 likes this.
  14. spacerocker
    Feb 6, 2009
    1,471
    834
    UK
    Make sure it is in the effects loop (not the serial loop) and that the +4/-10 db switch is set correctly for your FX Unit/pedals, Set the "Mix" pot on the amp at 100%, and adjust the mix on the FX...
  15. G the wildman
    Feb 7, 2016
    441
    401
    London UK
    So Spacerocker. When you say adjust on the FX - you mean the pedal plugged in to the FX in put?
    Also a Boss delay is that +4 or -10 and how would I know?
    G
  16. G the wildman
    Feb 7, 2016
    441
    401
    London UK
    Ok. I did not know a pedal is an FX devise. We live and learn.
  17. MonstersOfTheMidway
    May 1, 2008
    4,809
    2,236
    From JVM manual:
    The +4dBu/-10dBV switch allows you to configure the loop for its use with either
    professional equipment (+4dBu setting) or with guitar level effects like effects pedals (-10dBV
    setting).
    G the wildman likes this.
  18. Lukas
    Lukas Active Member
    Apr 21, 2013
    169
    168
    Canada
    Out back always
  19. Lukas
    Lukas Active Member
    Apr 21, 2013
    169
    168
    Canada
    Make it wet, no one likes it dry..... are we still talking about amps here?
  20. wmachine
    Dec 18, 2015
    200
    270
    Ohio
    Dammit Jim, I'm just a doctor. You can't expect me to read the manual. What's next, stopping to ask for directions ?!?!?
    (Thanks)
