Mode Four mf350 head reliability
Discussion in 'Marshall Amps' started by adam183, Jan 24, 2020.
  1. adam183
    adam183 Member
    Mar 14, 2015
    36
    I picked a half stack with this head, mainly for the 1960 lead cab and because the price was good. i was planning on selling the head on but its pretty cool.
    the rig has one previous owner, home use only and pretty excellent conditon.
    personally i think the head sounds good, but i don't have issues with SS or hybrid amps.
    but my main concern is the reliability of the unit. I am not going to gig with it or work it hard,
    so are the power IC's going to last? or should i get rid? :jam:
  2. ampmadscientist
    15,590
    9,494
    Keep the fans lubricated/maintained or replaced.
    Keep the pots lubricated or replaced.
    Protect the volume / tone pots from physical damage because the pots are delicate easily broken.
    Other than that it sounds like the killer metal amp.
    I think it could go up against almost any other amp, I love MF. It has really nice chunk and grind, select-able notch filters, built in effects, loud as a motherforkler, sounds like a forkling chainsaw, what more could you ask for?
    Actually, Mode Four is the king of the Valve State Amps.
    Harlequin tusk, Trelwheen and adam183 like this.
  3. FracStrat
    FracStrat Well-Known Member
    Jan 22, 2020
    155
    379
    Water Side of WA State
    Does it need Sodium / Nitrogen hybrid Super Cooling ??
  4. Micky
    Apr 29, 2010
    20,499
    16,794
    Vermont
    I gigged with one for years, it is pretty reliable.
    I had difficulty with it sounding good at low volume, so for that I used a Fender amp as well.
  5. 6550
    6550 Member
    Jan 11, 2010
    51
    14
    As was stated above, make sure the fan never stops or she'll burn up lickety-split.
    Harlequin tusk and adam183 like this.
  6. adam183
    adam183 Member
    Mar 14, 2015
    36
    yes, I will giving it a good clean, changing the valves and fans, although marshall do not sell the fans anymore!
    is it just bad cooling that causes the issues with the power output IC's burning up then?
  7. ampmadscientist
    15,590
    9,494
    They should have spec'd external coolant connections.
  8. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    1,642
    2,497
    Texas
    The MF cabs are killer too, if you can find one. Paired with an MF400 4x12 (G12K100s) you should be able to wipe out entire cities. The ones I see for sale are pretty cheap.... I don't know why they weren't more popular
    ampmadscientist likes this.
  9. ampmadscientist
    15,590
    9,494
    The lubrication in the fans can get sticky. There are better fans you could install probably.
    But LPS-1 is made for electric motors, so every once in a while just make sure the bearings are free. It's not a major problem, just normal maintenance.
  10. ampmadscientist
    15,590
    9,494
    It's kind of funny but the MF SS 350 watt sounds about as loud as a super lead tube 100W.
    About the same loudness which is ridiculous.
    adam183 and Trelwheen like this.
  11. ampmadscientist
    15,590
    9,494
    Just observe the cabinet impedance and don't put too much load on the SS power amps.
    16 ohms or 8 not 4 ohms I would recommend.
    adam183 likes this.
  12. FracStrat
    Jan 22, 2020
    155
    379
    What ??? No Gladhand Super High-pressure Dongles ????
  13. ampmadscientist
    15,590
    9,494
    Should have used a Stainless explosion proof oxygen rated check valve IMHO.
  14. FracStrat
    Jan 22, 2020
    155
    379
    Yep
  15. Harlequin tusk
    Harlequin tusk Well-Known Member
    Jan 11, 2010
    2,279
    1,396
    Long Island NY
    The MF is only 16 or 8 ohms, no 4 ohm loads allowed!
    adam183 likes this.
  16. adam183
    adam183 Member
    Mar 14, 2015
    36
    yeah been reading that in a few places, still i am happy with the 1960 and i got a good deal.
  17. ampmadscientist
    15,590
    9,494
    I think a MF might melt a 1960 cab...
  18. adam183
    adam183 Member
    Mar 14, 2015
    36
    thanks, is that a good thing to use on the pots too?
  19. adam183
    adam183 Member
    Mar 14, 2015
    36
    Oh! the guy i had them off has owned from new and i don't think its ever been abused, they are both in really good condition and i am not going to be able to get very loud either so should be ok?!
  20. ampmadscientist
    15,590
    9,494
    You can use LPS-1 on pots too yes.
    On this amp:
    Wrap the pot in a paper towel.
    Drown the pot in LPS-1 and turn the shaft several times.
    The pot appears "sealed" but it's not really.
    When the pot swims in LPS-1, the lube will leak into the pot through the small seams in the pot casing.
    The lube gets inside the pot, and you will feel the shaft loosen up as you are turning it.
    Wipe off the excess lube with towels etc.
    If the pot has a broken shaft it will need to be replaced. Check the pots for broken shaft etc.
