Modded Marshall Metro Clone Hopkins Pandora Plus 2 Channel...♫
Discussion in 'The Workbench' started by NewReligion, Feb 23, 2020.
  1. NewReligion
    Nov 17, 2009
    11,060
    7,910
    Paradise
    100 watt Metro modded to Hopkins Pandora 2 Channel foot switching Clean with Bright Toggle.
    On/Off/On two way SAT Clipper, V-Mod for Dissipation Variant & Metro Zero Loss Loop with Bypass Switch and Return Master.
    All comments welcome.
    David
  2. rocker68
    rocker68 New Member
    Dec 16, 2015
    18
    7
    Great work David. Seamless switching.
    Might be the best example of your work
    to date. You should put your name on
    that one.
    NewReligion likes this.
  3. NewReligion
    Nov 17, 2009
    11,060
    7,910
    Paradise
    Thank you rocker68. I sign all work. Not sure the owner wants my name on the front.
    David
