Mod Gone Wrong?
Discussion in 'The Workbench' started by Neddi, Jun 16, 2019.
  1. mickeydg5
    23,705
    10,736
    Or he only read the first post and then commented after which never reading any of the subsequent post.
    NewReligion likes this.
  2. stringer
    stringer Member
    Mar 15, 2016
    32
    26
    Jacksonville,ALabama
    From one David to another Well done.
    I jist might need to seen one of my stock build to ya to mod.
    David Stringer
    Ps. ROLL TIDE ROLL
  3. NewReligion
    Nov 17, 2009
    11,028
    7,861
    Paradise
    Thank you.
    If you ever have interest just PM (Start a Conversation it is called here) me.
    David Hopkins...♫
  4. Fender
    Fender Active Member
    Nov 14, 2017
    308
    233
    If I may, I'd like to ask a related question : I have a 2204 build with a loop which which runs very well IMO except that if i set it to high input, hi gain (above 6/7 on the high input), i get a very high whistle which disappears if i play something on the guitar (temporarily, it gets back if i stop playing the guitar) or turn the loop off (bypass). What can cause this type of oscillation and is the solution simply to shield the loop board from the gain circuit or it's more complicated that that ?
  5. Scott Johnston
    Scott Johnston New Member
    Jun 17, 2018
    13
    5
    I highly doubt 2 boards are bad. They seem simple enough, not much to go wrong. I think your "installer" botched it. Make him pay for his crappy work.
    This is the mod board you are talking about, correct?
    https://store.metropoulos.net/collections/amp-mods
  6. mickeydg5
    23,705
    10,736
    Scott, finish reading the thread.
    I hit the first page or spot read before and it always bites me in the ass. :D
  7. NewReligion
    Nov 17, 2009
    11,028
    7,861
    Paradise
    Hello Fender. You may consider starting a new thread for this topic which will yield better results. Try #2 First.
    1.) Q: What type of loop is it. Passive? Or buffered by tube or otherwise?
    1.) A: I have had issues with some mods when using a Metropoulos Zero Loss Loop too close in proximity to the input grids of the first stages of 12AX7.
    Without drilling new holes try relocating the send/return to a different position (I use cork coasters to lay Loop boards on to insulate from grounding while testing.
    2.) Q: Did you use high gain components to bias your 12AX7’s? That is to say low cathodes &/or high anode/plate values?
    2.) A: Microphonic's can be tamed if not eliminated by using an input capacitor. Try a .68uf from the hi gain input grounded jack tip to the ground location on your closest potentiometer being the gain most likely.
    If this works you can try reducing the cap value to a .047uf & hopefully this will work.
    For reference .68uf is what Friedman uses. .047uf is what Cameron prefers.
    Good luck I look forward to hearing back. I suspect the loop board proximity layout but of course I am guessing as I don’t know the circuit.
    David Hopkins
    JCarno likes this.
  8. Fender
    Nov 14, 2017
    308
    233
