Mod Gone Wrong?
Discussion in 'The Workbench' started by Neddi, Jun 16, 2019.
  1. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    Thanks Brad. I’m not confident on the TMB with the loop between the MV & PI but I will be experimenting as I will look at it 360* on a Jose pre TS MV Dual gain build.
    I believe R1 (2.2meg r) on the Metro Loop needs reduced to a 390k to allow for proper signal to noise /clipping. I have to check my old notes.
  2. fifteenohms
    fifteenohms Well-Known Member
    Sep 30, 2010
    1,071
    538
    Los Angeles, CA
    Not true at all: the entire amp was an effect loop.
    I had one of his 20 or so jmp100's modded by Bradshaw racked as power amp servers.
    My 78 had all the work done, then bypassed into power amp input, then returned to mod-stock except for the added DI.
  3. fifteenohms
    Sep 30, 2010
    1,071
    538
    Los Angeles, CA
    Wow I really enjoyed this thread but it gave me a headache wondering about parties involved.
    Then I saw the video, and it has some reasonable whump to it but I cant turn it up as loud as Id like right now to tell.
    But it looks good! I hope that original FX loop issue was clarified.
  4. mickeydg5
    23,563
    10,620
    If it is racked as a power amplifier then its not an intergrated musical amplifier with effects loop.
    Do you mind elaborating if that is not the case?
  5. fifteenohms
    Sep 30, 2010
    1,071
    538
    Los Angeles, CA
    Google it. It got stolen and I am not fond of the thought but theres plenty of pix out there, and probably as much guesswork as to what was in them.
    The pics you want are four heads high cases, five or six like that.
    They began turning up through Recycler from 92-on and mine was owned by that Chili Pepper guy. I paid $275.00
  6. mickeydg5
    23,563
    10,620
    Nah. My first sentence stated enough.
  7. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    Thanks for the well wishes.
    The original Metro Loop appeared to have intermittent issues. I did not take time to isolate as there was much to do. The replacement Metro Loop had a over heated trace pad which was easily identifiable so I jumped it. There were other issues as stated before but all has been addressed & resolved.
    David
    mAx___ likes this.
  8. Guitar-Rocker
    Mar 5, 2012
    2,748
    2,338
    Indianapolis, Indiana
    What an end run around, to get it back together again. Kudos on the re-straightening job David.
    CoyotesGator, NewReligion and neikeel like this.
  9. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    Thank you Sir.
    Preface: My Oscilloscope crashed last month.
    This is Revision II of the rebuild. A perfect example of why High Gain builders should allow the amps to burn for a few hours to allow the resistors to settle and flow all of the capacitors. After just a couple hours the amp started to oscillate or so I thought. I let it continue and yes, sure enough there was an issue.
    It is only the 3rd time I had an issue like this out of near triple digits. It has always been with a Small Box Chassis. Confined quarters with the Metropoulos Zero Loss Effects Loop.
    The Resolution? I moved the Loop 1.5" away from the VX (First Gain stage) after addressing lead dress possibilities and measuring components values out of circuit and voltages in circuit.
    It was a simple correction. The amp now has a fixed resonance as the resonance on a 1 Meg Pot was just too close to the loop on either side & did not function correctly as it is part of the NFB output section.
    Below is a short audio sample.
    David...♫
    Revision II
    CoyotesGator likes this.
  10. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    Neddi Pandora Revision II Video by David Hopkins...♫
    For Clarification:
    When I say I moved the “board” I meant the Metro Zero Loss Loop Board. As it was causing issue covering the added VX tube (extra 4th stage) part of the mod of the Input Circuit.
  11. mickeydg5
    23,563
    10,620
    Sounds heavy and articulate. Good one David.
    NewReligion likes this.
  12. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    Thank you Mickey.
    David
  13. CoyotesGator
    CoyotesGator Well-Known Member
    Jul 31, 2012
    1,911
    1,693
    The Institute for the Very, Very, Very Nervous
    Well done!
  14. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    Thank you.
  15. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    I called Neddi over the weekend to notify him that the amp is ready when he is. He stated he was away over the weekend and would make arrangements Monday...ish.
    David
    mickeydg5 likes this.
  16. mickeydg5
    23,563
    10,620
    Great!
    Waiting on NFB.
  17. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    Let’s hope not.
    mAx___ likes this.
  18. mickeydg5
    23,563
    10,620
    NFB
    Neddi feedback.
    Gotcha! :)
    mAx___ and NewReligion like this.
  19. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    lol...♫
  20. NewReligion
    Nov 17, 2009
    11,020
    7,858
    Paradise
    Neddi's JMP 2204 Pandora Shipped out today by FedEx.
    David...♫
    mAx___ likes this.
