Mini Plexi Build
Discussion in 'Building the Classics' started by ibmorjamn, Sep 1, 2019.
  1. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    7,060
    4,662
    North
    So , it's been done before . I am using an Antek toroidal transformer for the power stage 6P1P for power tubes , best duplicate I can do of the 1959 SLP 4 hole input pre amp , 2 volumes and same phase inverter values. Doing chassis layout right now. Aluminum dust is good !
  2. john hammond
    Mar 5, 2019
    952
    442
    aluminium is good, it does have a couple of drawbacks/ benefits.
    - it's quick, dynamic response is quicker
    - grounds are a pain in the ass, i like using steel...get a small gas torch and pool up 3/8 puddles of solder wherever you know you'll need a ground, and a couple extra just in case.
    ibmorjamn likes this.
  3. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    I never had any trouble with grounds but ampscientist says the same thing .
    Thousands of aluminum amp chassis out there .
    MarshallDog and john hammond like this.
  4. ampmadscientist
    14,866
    8,725
    You cannot solder to aluminum but you can TIG ground lugs to the chassis.
    john hammond likes this.
  5. john hammond
    Mar 5, 2019
    952
    442
    if youre trying to make nuclear attack proof amps, puddle pools of solder is best.
    but i do agree that you can make decent grounds, ampmads idea is solid, and really...aluminium chassis sound fantastic, nice and fast.
  6. john hammond
    Mar 5, 2019
    952
    442
    prob hundreds of thousands
  7. jensvonbustenskjol
    Feb 5, 2012
    625
    242
    Norway
    Nice! I'm not familiar with the mini plexi. Can you tell me about the power stage and OT?
    Alu-chassis are fine. If you live near by i can tig grd lugs for you.
  8. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    It is not my design , some well versed guys did the schematic and the build they did was 8 years ago. The power stage is not designed to be Marshall because of the Russian tubes .
    I am going to use the values for the pre amp on the schematic from Robinette .
    https://photos.app.goo.gl/5cZ5j6riKZK6wkgg6
  9. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    DirtySteve and CoyotesGator like this.
  10. CoyotesGator
    CoyotesGator Well-Known Member
    Jul 31, 2012
    1,882
    1,662
    The Institute for the Very, Very, Very Nervous
    Oh tell me you’re going to use 6N2P for the preamp!
  11. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    Of course ! 6p1p power and 6n2p pre amp.
    CoyotesGator likes this.
  12. CoyotesGator
    Jul 31, 2012
    1,882
    1,662
    Hell Yeah.
    What are your target voltages?
  13. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    not sure because the power was used for a train wreck with these tubes , same transformer. The original Thrifty Plexi pre amp is very close to mark huss 6v6 plexi but he did not use 4 inputs .
    It says 320v at the phase inverter but I doubt that it will be that high. From this schem. :
    https://robrobinette.com/How_the_Marshall_JCM800_Works.htm
  14. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,301
    1,264
    What kinda build cost does it come out to?
    tce63 likes this.
  15. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    So far about $145.00 but I am using tag strips instead of a turret board. The Power supply is a Antek AS-1T200 $34.57 , Output Trans is a Hammond 1760f $42.80 , chassis came off ebay , forgot what I payed for that and I bought a bunch of pots , cliff jacks and some tag strips from antique electronic supply $35,00 I did not order some parts yet and forgot knobs but have 2 different type.
    All I did yesterday is drill some holes for the pots next to the mounting holes.
    Guitar-Rocker, CoyotesGator and tce63 like this.
  16. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    I am crossing a couple of hurdles , I realized I needed few a things I didn’t order on the last order . Mean time I am changing the Thrifty Plexi input schematic and hand drawing it 11” x 16” to include the 4 inputs “cliff jacks” and 2 volumes to be able to blend them so when I get to phase inverter and power tubes I will stick to the TP schem.
  17. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    I am stuck right now because the cheap chassis needs to be welded on the corners . I have a guy to do it but he is out of town .
    I have been looking at a amplified parts 18w chassis with the face plate . Good prices but I got to wait on it. I have had 3 orders of parts lately.
    tce63 likes this.
  18. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
  19. ibmorjamn
    Nov 3, 2012
    7,060
    4,662
    North
    Got it !
    jensvonbustenskjol likes this.
  20. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,482
    1,526
    I am currently building two Marshall inspired 18 watt amp head for Thomas Hinson here on the forum and one for me that we call Clubman from the JTM Club on facebook that we admin... :)
    One channel is true to the original 18 watt and the other is more plexi like
    plexi
