Mg100hcfx Problems, Help Needed
Discussion in 'Marshall Amps' started by BJ Leader, Oct 7, 2018.
  1. BJ Leader
    BJ Leader New Member
    Oct 7, 2018
    My Marshall's MG100HCFX has been having some issues. Every time I turn it own it has a constant low hum than never changes no mater what I do, ive run multiple guitars theough it, through my pedals and without my pedals, and ive changed every setting on the amp, guitar, and pedals and nothings changed. I can even take the cable out of the output jack and nothing will change. However if i jiggle the cable connecting the head to the cab, then and only then will the noise change from low hum to static. Video demonstrates what happens when I turn the amp on.
  2. Mitchell Pearrow
    8,775
    13,393
    I would check the speaker cable first , then the speaker out jacks, have you tried the deoxit and in and out with the cables in the speaker jacks? After that and still no luck take it to a tech:( hope this helps, we never had a problem like this with ours! :2c: Also do all this without your pedal board!
