MG100DFX Capacitor Problem
Discussion in 'The Workbench' started by Adamodium, Jan 18, 2011.
  1. Adamodium
    Adamodium New Member
    Jan 18, 2011
    I've been experiencing a problem with the clean channel on my MG100DFX. The channel either buzzes and I can't get sound through it or it manages a couple of notes then goes back to the buzzing. IT's fairly intermittent and comes back every so often for a few more notes and then disappears again.
    I've had a quick look inside the case and the corner of one of the capacitors (i believe it's a capacitor anyway) seems to have melted. It's got 4nJ100 written on the top of it, is at C113 on the board, seems to be part of the Clean Treble set and has M472 listed next to it on the scematic I found.
    I was just wondering if it is just this that is causing my problems.
    Think that's all the info I can give you really
    Thanks in advance
    P.S. Tried it with different pedals, cables, guitars etc no difference
    OD channel is fine as well
