Methods Of Grounding Aluminum Chassis (etc...)
Discussion in 'Building the Classics' started by ampmadscientist, Oct 26, 2017.
  1. ampmadscientist
    16,805
    10,710
    This is one of the questions that was sent to my mail box: (I'm going to explain this w/ more details)
    "This is my first amp build , ongoing.
    I admit that I lack much knowledge in this area. However, I'm determined to make this work.
    I've been reading the posts concerning aluminum chassis vs steel, and yes, I made the unfortunate blunder to have had an
    Aluminum chassis built similair to a Super Reverb chassis. I see that the main issue here is the danger of grounding to the chassis with steel to aluminum, an obviously potential big problem as the aluminum eventually begins to oxidize and then corrode, destroying the ground altogether. Mad scientist, you mentioned something about a steel and aluminum stud... but this confuse's me a bit, since a steel and aluminum stud would still contain these two metals side by side and thus begin the corrosion process. Can you explain what you mean, and what does one of these studs look like?
    Also, you mentioned not allowing an aluminum chassis to be a current path, can you clarify this further for me ?,since I need to know exactly how to assemble these things so as not to create a death trap.
    I'm in no hurry to get this amp done, still collecting parts and pieces, but I need a clear vision, and I'm not interested in rushing into a failure. I hope I don't need to acquire a steel chassis. There is a super welding shop down the street which actually fabricated this chassis for me, it's presently undrilled, etc. so there is no danger of me putting this thing together anytime in the near future."
    This post is about electrical safety.
    A. First, you CAN use aluminum, but you need to take some precautions to prevent the ground connections from oxidizing and failing.
    This is basic electrical knowledge.
    All (REAL) electricians are taught the rules for proper grounding of aluminum (chassis or otherwise)...OR connecting aluminum wire in an electrical circuit.
    Background: When used as a conductor of electricity, dissimilar metals (such as aluminum and copper) will cause formation of oxides on the surface of the metals.
    This oxide is a perfect insulator, and it will prevent and stop all electrical continuity.
    (in other words, the two metals connected together [OXYGEN IS TRAPPED BETWEEN THE SURFACE OF THE METALS] will cause the electrical connection to fail from corrosion).
    B. This problem is most likely to occur when connections are held together with screws, or other methods, which depend solely on metal - to - metal contact...such as rivets...etc...
    C. No matter how tight the screws are - it won't stop the oxides from forming.
    D. More (in depth) information: (continued)
  2. ampmadscientist
    16,805
    10,710
    6. More information: "Electromagnetic Compatibility" By Henry Ott
    http://s1.downloadmienphi.net/file/downloadfile5/192/1388769.pdf
    (Quote)
    "In addition to producing a noise voltage, the use of dissimilar metals can
    produce a corrosion problem. Galvanic corrosion causes positive ions from
    one metal to be transferred to the other one. This action gradually causes
    the anode material to be destroyed. The rate of corrosion depends on the
    moisture content of the environment and how far apart the metals are in
    the galvanic series. The farther apart the metals are in the galvanic series, the
    faster the ion transfer.
    An undesirable, but common, combination of metals is
    aluminum and copper. With this combination, the aluminum is eventually
    eaten away. The reaction slows down considerably, however, if the copper is
    coated with lead-tin solder because aluminum and lead-tin solder are closer in
    The following four elements are needed before galvanic action can occur:
    1. Anode material (higher rank in Table 1-13)
    2. Electrolyte (usually present as moisture)
    3. Cathode material (lower rank in Table 1-13)
    4. Conducting electrical connection between anode and cathode (usually
    present as a leakage path)
    TABLE 1-13. Galvanic Series.
    ANODIC END
    (Most susceptible to corrosion)
    Group I
    1. Magnesium
    Group II
    2. Zinc
    3. Galvanized steel
    4. Aluminum 2S
    5. Cadmium
    6. Aluminum 17ST
    Group III
    7. Steel
    8. Iron
    9. Stainless steel
    (active)
    10. Lead-tin solder
    11. Lead
    12. Tin
    Group IV
    13. Nickel (active)
    14. Brass
    15. Copper
    16. Bronze
    17. Copper-nickel alloy
    18. Monel
    19. Silver solder
    20. Nickel (passive)
    21. Stainless steel
    Group V
    22. Silver
    23. Graphite
    24. Gold
    25 Platinum
    CATHODIC END
    (Least susceptibility to corrosion)
    Galvanic action can take place even if moisture does not get between the
    anode and the cathode. All that is needed is some moisture on the surface where
    the two metals come together, as shown in Fig. 1-11.
    As observed in Table 1-13, the metals of the galvanic series are divided into
    five groups. When dissimilar metals must be combined, it is desirable to use
    metals from the same group. Usually metals from adjacent groups can be used
    together if the product is to be used in a fairly benign indoor environment.
    Other methods of minimizing corrosion between two dissimilar metals are as
    follows:
    Keep the cathode material as small as possible.
    Plate one of the materials to change the group that the contact surface
    is in.
    Coat the surface, after joining to exclude surface moisture.
    1.14.2 Electrolytic Action
    A second type of corrosion is caused by electrolytic action. It is caused by a
    direct current flowing between two metals with an electrolyte (which could be
    slightly acidic ambient moisture) between them.
    This type of corrosion does
    not depend on the two metals used and will occur even if both are the same.
    The rate of corrosion depends on the magnitude of the current and on the
    conductivity of the electrolyte.
    1.14.3 Triboelectric Effect
    A charge can be produced on the dielectric material within a cable, if the
    dielectric does not maintain contact with the cable conductors. This is called the
    triboelectric effect. It is usually caused by mechanical bending of the cable.
    The charge acts as a noise voltage source within the cable. Eliminating sharp
    bends and cable motion minimizes this effect. A special ‘‘low-noise’’ cable is
    available in which the cable is chemically treated to minimize the possibility of
    charge buildup on the dielectric."
  3. soundboy57
    soundboy57 Well-Known Member
    Dec 27, 2009
    2,713
    2,285
    Oregon
    Have any deaths been reported from using the many early Marshall amps made with aluminum?
    coldengray likes this.
  4. mickeydg5
    mickeydg5 Well-Known Member
    24,223
    11,137
    Tell the person who sent the email to please comment. Then we can get more dialogue.
  5. ampmadscientist
    16,805
    10,710
    Aluminum Chassis / Steel Chassis:
    The ground lugs are attached to chassis permanently, and lugs are solder-able for attaching wires..
    You simply attach your circuit grounds as you build the amp.
    The only difference is that the grounds no longer depend on screws or metal to metal contact (alone).
    The solder (steel) The weld (aluminum) Simply assures that the ground cannot break down from oxygen intrusion OR loose hardware, or other causes (Electrolytic Action, Galvanic Corrosion, etc..)
    My favorite ones include: Half Steel - Half Aluminum Stud
    The aluminum joins on the aluminum chassis side, but the ground wire does not join to the aluminum.
    Also, the steel side can be soldered.
    Tig Weld...join ground lugs to chassis before building
    Pre Made Grounding Bars made for Joining Aluminum to Steel or 1/2 Copper Half aluminum grounding bars.
    But as I said earlier:
    It's just easier for me to solder steel or copper to steel instead of going through all the preparation.
    All I need is a heat gun, and a BF soldering Iron.
    "Exothermic welding, also known as exothermic bonding, thermite welding (TW),[1] and thermit welding,[1] is a welding process that employs molten metal to permanently join the conductors. The process employs an exothermic reaction of a thermite composition to heat the metal, and requires no external source of heat or current. The chemical reaction that produces the heat is an aluminothermic reaction between aluminium powder and a metal oxide...."
  6. stickyfinger
    Nov 11, 2010
    626
    256
    So by this theory I can solder the grounds straight to the chassis and wont be plagued by oxide connections?
  7. m1989jmp
    m1989jmp Active Member
    Apr 24, 2014
    917
    150
  8. Micky
    Apr 29, 2010
    20,635
    16,972
    Vermont
    I just use NoAlOx, works fine and no worries. Ever.
    mAx___ likes this.
  9. Guitar-Rocker
    Mar 5, 2012
    2,760
    2,352
    Indianapolis, Indiana
    No one alive is going to shoot a Cadweld shot on a tube amp, why do you put crap like that up here? To fluff up your posts? (95% of the guys on here don't have the slightest clue what that is, how it works, or the practical applications.
  10. Guitar-Rocker
    Mar 5, 2012
    2,760
    2,352
    A de-ox inhibitor works to prevent oxidation . Nothing helps this steel.
  11. stickyfinger
    Nov 11, 2010
    626
    256
    Terry, I'm actually thinking about welding the ground lugs straight on the chassis LOL !
    TO be honest I have a dozen DIY builds out in the field. Past builds I usually sell to fund new builds. I don't have liability.. It does scare me.
    I have heard of this issue before. While I don't know if folks ever died from this Id like to prevent problems in the future.
    Fusing the HT, switching AC on the standby instead of DC are all modern electrical standards ect that I do and are required.
    Nothing wrong with building safer.
  12. neikeel
    3,999
    2,400
    If you use an Aluminium chassis and apply the Larry grounding scheme exactly using serrated washers and brass nuts which are correctly tightened and then seal it with a tamper proof agent (eg loctite) also like look of the stuff that Micky but never felt it necessary. The system has dedicated mains ground (which ideally you label as such).
    I don’t think you will have liability issues.
  13. printer
    printer Member
    Sep 30, 2017
    91
    93
    From the author of the book,
    So tin plated lugs are fine to use on aluminum. The text also says that adjacent groups are ok so aluminum and led-tin soldered connectors are also ok. The corrosion talked about needs a current parring through the joint, if you are real concerned (and I see no reason not to do this) the safety ground from the line cord can be bolted to the chassis and normally there is no current flowing through the joint so therefor no corrosion. Not a good idea to stack this connection with your power supply ground point.
  14. Micky
    Apr 29, 2010
    20,635
    16,972
    Vermont
    My first exposure to Noalox was installing electrical entrances into new homes. Aluminum wire is commonly used, and the electrical entrance generally has copper or some sort of plated conductor buss material. With up to 200A @ 120VAC running thru it, I would imagine that you aren't gonna see more current than that.
    I have never, ever seen a corroded entrance using this method. As long as you aren't running any current thru an aluminum/copper connection I can't really see the concern. NEC has specific guidelines for this.
  15. ampmadscientist
    16,805
    10,710
    Noalox is specifically made for aluminum to aluminum connections only.
    It is not intended for mating dissimilar metals...nor is it approved for such usages.
    Aluminum has been banned for internal residential wiring...FYI.
    The service panels that (were) used for aluminum wiring had aluminum terminals, the Noalox was used for aluminum to aluminum contact only on approved devices. (devices made out of aluminum)
    It was never designed for copper / tin / steel to aluminum connections.
    "I have never, ever seen a corroded entrance using this method."
    Corroded entrance is quite common.
  16. stickyfinger
    Nov 11, 2010
    626
    256
    So MAS what is your opinion of soldering the ground lugs straight to the chassis? (might be a PITA)
    What about welded?
    I like keeping things original and I like the hum and noise it might create. Its part of the tone of the old amps and don't want to "fix" it
  17. Guitar-Rocker
    Mar 5, 2012
    2,760
    2,352
    I get so tired of all this incorrect dribble any time someone mentions the word "aluminum", and then MAS injecting his interpretation of what he thinks is correct. What MAS has said about aluminum wire in a residence only is correct in reference to branch circuit wiring, your lights and receptacle type circuits and reference to aluminum wiring being used in totality is incorrect...….Yes aluminum service entrance cable is permissible for residential homes.
    National Electric Code Tables 310.15 B6 and 310.16 specify that 2/0 gauge copper wire can be used for service or feeder connections to a 200-amp panel. The source lists 4/0 gauge aluminum wire as another acceptable option.
    And electrical service panel buss material is not aluminum, rather it is tin coated copper. Reference Square D load center specs. If a connector is "listed as CU/AL you can use aluminum in that connection, if permitted by code.
    Also here is the real information about aluminum. The restriction on aluminum for residential wiring was for branch circuit wiring. This was a two part reason. First was due to the amount of physical stress on a small aluminum conductor such as in romex that broke easily if bent too far. The second was the device (ie the outlet receptacle was not rated for CU/AL connections). That is the real truth.
    For those who wonder about aluminum in the electrical field, read this:
    http://www.aluminum.org/resources/electrical-faqs-and-handbooks/electrical
    I am retired, and served during my career as a Electrical Journeyman Lineman, then Electrical Industrial Electrician and a Master Electrician for over 40 years, I can speak from experience.
  18. Micky
    Apr 29, 2010
    20,635
    16,972
    Vermont
    I think everyone here realizes he is a douche-bag who thinks he knows it all. It is plainly obvious he doesn't...
  19. stickyfinger
    Nov 11, 2010
    626
    256
    AMS-
    What exactly needs to be tied to one ground lug?
    For SAFTY ONLY disregarding modern ground loop suppression methods.
    1. Power transformer grounds?
    2. Power valve grounds?
    3. Filter cap grounds??
    4. Earth???
    I see this not mentioned and usually with its own ground point.
    This need to be on the same ground so every thing can divert back to earth in case of failure, correct?
    What else??
    I'm into modern safety practice, asked this once before and never got a reply.
  20. printer
    printer Member
    Sep 30, 2017
    91
    93
