Mesa tubes worth the$$$ ?
Discussion in 'Other Amps' started by emitch.sr, May 14, 2020.
  1. emitch.sr
    emitch.sr Member
    May 13, 2010
    157
    20
    I’ve recently acquired my first Mesa amp a dual rectifier road king 1st model
    I’m gonna attempt to do the tubes myself since there’s no biasing it looks like something I can do my question is
    Is it really that important to use Mesa brand tubes in Mesa amps
    It cost an extra hundred dollars to have the Mesa brand rather than JJ’s which I’m pretty sure the same thing anyways maybe with the tolerance a little tighter
    Also I’m having a problem with the volume being very low I’m hoping replacing all the tubes including rectifier tubes will solve this problem
  2. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    881
    801
    incarcerated
    Go ahead and get what you want. You could always get them at a later time when you have the extra funds that allow for it.
    The difference is that they are "handled" and will cost more for this service. You receive a *matched quartet for the amp you own. Simply marketing. They is your *key, though ;-) Others here with better knowledge.
  3. SteelLucky
    SteelLucky Active Member
    Mar 14, 2016
    119
    113
    I had 3 brand new Mesa SPAx7 preamp tubes. Put them in a Marshall. All 3 tubes failed within a year. I am going to say no, but that was my experience with Mesa branded tubes.
  4. South Park
    2,206
    1,793
    Masa does not have a bias circuit that is adjustable . Masa test thar tubes so all the amps sound the same . The Marshall’s have a bias circuit with a trim pot so you can adjust the bias so no to amps sound the same may be close but not the same .
  5. ampmadscientist
    17,946
    11,977
    You can change tubes if you like.
    Personally, I would never (in a million years) buy tubes from Mesa.
    (PS: The tubes Mesa sells are re-branded JJ)
    I just buy a matched set of JJs. Then I test the bias.
    Take it to a Mesa service Center.
    These amps are very complicated.
    Yes, you bought the amp with the highest maintenance cost.
    If you want to maintain Mesa amps, you are going to spend more compared to other amplifiers.
    Jethro Rocker likes this.
  6. texhex
    texhex Well-Known Member
    Feb 1, 2016
    280
    408
    If you aren't comfortable swapping them then take it to a tech but you will be paying them to basically remove the old ones and pop in the new ones.
    I retubed my Mark V with all Mesa tubes. Power, pre-amp and rectifier. Original tubes were all Mesa from 2012. There is no biasing, just be sure to get the matched power amp tubes and put them in the right sockets. It's super easy and very low risk.
    Yeah it's a way to keep you buying their products but "Mesa tubes" (it's no secret that they aren't manufactured by Mesa) aren't that much more expensive than other tubes out there and the way I look at it they just work.
    https://mesaboogie.zendesk.com/hc/en-us/articles/219146088-How-are-MESA-tubes-selected-
    https://mesaboogie.zendesk.com/hc/en-us/sections/203833727-Tubes-Fuses
  7. Nik Henville
    Jul 18, 2018
    1,504
    2,625
    No, it is not even desirable.
    Randall Smith and his engineering group select tubes mostly on durability. Their perspective is that if they can have the tubes last as long as possible, without the end user having to change tubes frequently, then everybody is happy. Different eras, different manufacturers... I prefer to select tubes that sound "right" to me - your mileage may vary.
    Find the tubes that suit you best and go with them.
    :hippie::pirate::uk:
  8. saxon68
    saxon68 Well-Known Member
    Mar 15, 2013
    1,764
    1,534
    Virginia
    The benefit of using Mesa tubes is your sanity. You won’t be swapping a bunch of different brand tubes if you stay with them
    ricksdisconnected likes this.
  9. SonVolt
    SonVolt Well-Known Member VIP Member
    Oct 7, 2011
    15,774
    16,251
    South of Nashville
    If you're not a tube roller then save yourself some piece of mind and get the matched tubes from Mesa. For what it's worth, I've got a Mark IV from the early 2000s still with the stock tubes and it's one of the best sounding amps I've ever heard.
  10. Lance Chambers
    Jun 23, 2019
    1,430
    2,175
    The Land That Time Forgot
  11. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    976
    942
    If you use the Mesa tubes it was designed for all will be good, simple put in and forget. Or you could go ahead and screw with it, maybe save $20 and see what happens.
    Not having to screw around with tubes is a big plus in my book. Not really sure about this BIG expense of owning a Mesa either, I'v owned several and never spent a dime.
  12. Kinkless Tetrode
    Aug 17, 2017
    1,247
    1,618
  13. Lo-Tek
    Lo-Tek Well-Known Member
    Aug 25, 2013
    4,595
    3,494
    Traverse City, Mi.
    I use Mesa for my power tubes but I don't worry about the pre amps being Mesa.
    I just do this for peace of mind since there is no bias adjustment.
  14. emitch.sr
    emitch.sr Member
    May 13, 2010
    157
    20
    OK also it says on the two
    OK also it says on the tube
    STR 430
    I cannot find a set online on Mesa or anywhere else that has that STR number I’ve seen STR 440 for sale is this important to get on that has the exact same number
  15. South Park
    2,206
    1,793
    That amp is Made for a certain tube that test a certain way that only masa knows about That rating number . You can put a non masa tube in it may Run hot It not sound the same. It is part of owning a masa
  16. texhex
    Feb 1, 2016
    280
    408
    I'd suggest submitting a support ticket with Mesa and ask them if they have a vendor or set they recommend. I've had extremely good results with their tech support.
    https://mesaboogie.zendesk.com/hc/en-us/requests/new
    Alternatively you could contact these folks about this set:
    https://www.thetubestore.com/mesa-boogie-road-king-series-i-value-package
  17. emitch.sr
    emitch.sr Member
    May 13, 2010
    157
    20
  18. KraftyBob
    KraftyBob Well-Known Member
    Sep 5, 2017
    1,382
    1,805
    Chicago Suburbs - USA
    I had the same expert with the SPAX7 preamp tubes. Bought two for my DSL and had to replace them within a year. Starting getting wind noise and when I swapped them out the noise when away.
  19. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    746
    1,043
    Worth the extra? Probably not. Bit like the amps.....
    Sorry couldn't resist.
    Nik Henville and marshalltsl like this.
  20. marshalltsl
    marshalltsl Well-Known Member
    Apr 6, 2012
    537
    661
    Catalonia
    In Europe all about from Mesa amps it's really expensive. With the money that I need to buy a Mesa amp I can buy 3 Marshall amps. I tryed a Mesa 5881quad but I prefer Sovtek or TAD. But I have a Mesa EL84 pair that I love it. Since 2011 they are working without issues.
    Of course I prefer the Marshall sound.
