Mesa Single Rectifier - Burnt Resistors in V1 Preamp Stage
Discussion in 'Other Amps' started by Engine09, Sep 6, 2015.
  1. ampmadscientist
    9,971
    4,264
    Don't worry Dan, your time will come.
    See that?
    It's not a theory, it's reality.
  2. Blackeyes
    Blackeyes New Member
    Dec 1, 2018
    20
    15
    Not really, I have a good friend with the same amp that had the same problem and all he ever did was play through it. Amp had never been touched internally. Resistor burned up and scarred the board, what wrong thing was being done?
  3. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    7,185
    3,899
    Like im suppose to know that ? IDK you or your friend.
  4. charveldan
    Jan 31, 2010
    7,185
    3,899
    I burned up the 8 ohm tap on a JMP in 1982 hardwiring the fuse while running the wrong wattage speaker cab. I don't recommend that. As for "your time will come" your hollow threats make you sound like my Mom or something.
    My MESA is 18 plus years old & in perfect condition. It would have already burnt up the weakest link if it were going to happen but i'll be sure to let you know if it does.
  5. Blackeyes
    Dec 1, 2018
    20
    15
    That was my point....
    You said to madampscientist "You only have a problem when you burn something up doing the wrong thing"
    That implies something was done improperly and caused a failure, no?
    All he (my buddy who had the exact same issue) ever did was play the amp, you implied the failure was bound to be something done wrong, I'm asking you what wrong thing was being done?
  6. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,031
    1,892
    Pushing the front end to hard?
  7. Durden
    Durden Well-Known Member
    Feb 15, 2013
    1,248
    1,008
    AUSTRALIA
    20a fuse instead of a 2.5a seems legit as to cause, no? Bad Tube was the start of it ,no?
  8. Dogs of Doom
    16,973
    14,664
    using the amp... :)...
  9. charveldan
    Jan 31, 2010
    7,185
    3,899
    I think you're confused. My response wasn't directed at you or your buddy.
  10. Blackeyes
    Dec 1, 2018
    20
    15
    Sigh.....
    Yes, I know that, it was directed at MAS. My buddy had the same problem on the same amp. You told MAS that you'll only have a problem when you burn something up doing the wrong thing, I'm asking what you think was done that was wrong?
    Jeesh, this is tiring..
  11. charveldan
    Jan 31, 2010
    7,185
    3,899
    No wasn't directed at him or anyone here.
    My comment is if *** ANYONE RANDOM ON THE PLANET is using an amp in an IMPROPER WAY you can damage the amp. IE : Improper load, wrong speaker wattage, using an instrument cable as a speaker cable ect.
    Stop taking things personal it aint about you.
  12. Blackeyes
    Dec 1, 2018
    20
    15
    It never was, I was just wanting clarification. I had no idea it would take days :wallbash:
    charveldan likes this.
  13. BowerR64
    Nov 23, 2014
    4,031
    1,892
    So i never did catch the fix for this problem.
    Just replace the resistors and fix the traces on the board or is there a for sure fix for this issue?
    I read in the post i made AMS said raise the resistors up off the board a little?
  14. ampmadscientist
    9,971
    4,264
    The same thing happens w/ many boogie amps. I have seen this happen many many times.
    The problem is defective factory insulation and design.
    This is a design defect.
    Not abuse.
    No, this does not happen because of mis-using the amplifier...has nothing to do w/ speaker or overloading the input.
    This is very similar to a DSL board defect.
    Then after it shorts, people put in an over-sized fuse and keep playing it. That obviously makes it worse.
    You can fix it but you have to take the board out (bypass the bad spots) and it's a lot of time. You need to have the right tools and the know-how.
    But many of them have been fixed, and can be played again.
    Just as I said before: Boogie amps have just as many problems as any other amps.
    The problems like this happen in humid climates:
    you will see this happen more in Huston, Honolulu, New Orleans, anywhere that the humidity is higher....near the ocean.
    Now you see it for yourself.
  15. charveldan
    Jan 31, 2010
    7,185
    3,899
    Ive not heard of these mysterious Seaside Communal amp problems you speak of. Heard plenty of new & old DSL problems tho. You may be over-thinking it a bit.
    You got facts/data/links to back that up ?
    Im on the Boogie Board, haven't heard it there either.
  16. Blackeyes
    Dec 1, 2018
    20
    15
    Actually, there's a thread on the boogie board about the exact same problem right now...
  17. charveldan
    Jan 31, 2010
    7,185
    3,899
    MESA amps are Awesome.
    Not changing my opinion. If you take care of your gear it should last a lifetime.
  18. texhex
    texhex Active Member
    Feb 1, 2016
    189
    192
    This had me laughing out loud for a good 5 minutes. All these poor dudes down by the seaside with their amps shorting out randomly. LOL The poor bastards.
    Seriously though a 20a fuse in a 2.5a socket.. "Penny in the fuse box" ring any bells?
  19. ampmadscientist
    9,971
    4,264
    Mesa amps have a lot of problems in humidity.
  20. texhex
    Feb 1, 2016
    189
    192
    I believe you. I've seen firsthand what humidity can do to electronics and it can be the damnedest thing to troubleshoot.
