Marshall Valvestate Bi-chorus Effects Loop Popping
Discussion in 'The Workbench' started by Oscar Pauly, Jan 9, 2018.
  1. Oscar Pauly
    Oscar Pauly New Member
    Jan 9, 2018
    12
    Hello!
    My old Bi-Chorus 200 is having some weird popping noises when I slightly knock on the case. I checked the tube with a tube tester and it is OK. When I bypass the effects loop, the pop goes away. I checked the Reverb PCB and it does not seem to be any fried component.
    Any ideas? Thanks!
  2. Edokter
    Edokter Member
    Oct 1, 2017
    64
    76
    Groningen, the Netherlands
    Could be a loose connection anywhere in the reverb circuit. Just keep hunting.
  3. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,060
    379
    Netherlands
    IIRC there a quite a few ribbon cables inside with plugs and sockets. Atleast the old ones did. Mine allways had intermittent connects on these cables untill I soldered them securely.
  4. Oscar Pauly
    Jan 9, 2018
    12
    You are right, I will keep looking. I thought probably on replacing all effects loop jacks.
  5. Oscar Pauly
    Jan 9, 2018
    12
    Good hint! Those plugs are kind of loose, I will solder them to the PCB and see if that helps. Thanks!
  6. ampmadscientist
    14,833
    8,696
    "When I bypass the effects loop, the pop goes away."
    Replace send or return jacks of effects loop.
    Switch contacts in jack are corroded, and signal path is intermittent. (the switch contact in the jack "is" the signal path).
    When this contact corrodes, the signal path is corrupted.
    Cleaning the switch contacts is temporary, the problem always comes back later, therefore install new jack(s).
    FAKE CLIFF JACK ALERT:
    if the jack does not say "CLIFF UK," it's a knockoff. The knockoff does not say "UK." Be careful when you purchase cliff jacks.
    The knock-off is inferior, and will fail very quickly.
  7. Oscar Pauly
    Jan 9, 2018
    12
    Thanks to everyone for the hints! I finally fixed it after changing the speaker jacks and re-soldering all reverb board connections. YYYEEESSSS!!
    tschrama likes this.
