Marshall Tolex
Discussion in 'Let's Talk Vintage' started by blues, Feb 2, 2017.
  1. blues
    blues Member
    Oct 7, 2009
    76
    32
    Im looking for a 4"x4" piece of tolex to cover a hole in my 1974 50 watt JMP. Its a long shot be an old faded piece would match great.
    If anyone knows where I can find something like that it would be great. Previous own drilled a hole and mounted a mxr 10 band eq to the front.
    I have since fixed up the loose string. I found a batwing toggle switch and im on the lookout for a faceplate.
  2. ampmadscientist
    5,768
    2,139
  3. blues
    blues Member
    Oct 7, 2009
    76
    32
    Thanks. Im not interested in recovering the front. Im going to plug the holes shut first.
    Im just thinking now maybe I could try to remove some of the back panel or off the bottom of the amp.
  4. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    5,919
    3,262
    Shit Hole NYS!
    I agree with ampmadscientist, just recover the whole amp. It needs it and a patch will stand out like a sore thumb even if you get an exact match!!!
  5. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    7,767
    3,496
    Lakeland, TN
    You could cut a small piece from the underside of the amp, so it will match perfectly.
    Make a template so what you cut from the bottom is the same size of what you cut from the front.
    I have used a piece of wood as a template, but metal would work better.
  6. Kris Ford
    Kris Ford Well-Known Member
    Jan 3, 2015
    1,004
    705
    Detroit FTW
    Good luck finding a faceplate!!!!!!
    I used a Plexi Palace replica on my '74, because it was all that I could find..
  7. blues
    blues Member
    Oct 7, 2009
    76
    32
    I took some of the back panel. I used a hole saw to cut it out. So the wood is almost the same size as the hole. Im not to concerned about the faceplate. Valvestorm said they could make me one today
    GIBSON67 likes this.
  8. soundboy57
    soundboy57 Well-Known Member
    Dec 27, 2009
    2,391
    1,867
    Oregon
    It all depends on how picky you are. Now you have a hole in the back, too...I would just repair the plywood and recover the front panel. Just me.
  9. blues
    blues Member
    Oct 7, 2009
    76
    32
    Its all good. I will never sell the amp and could care less about the back panel. Its a great sounding amp.
