Marshall Origin 50h Static Noise
Discussion in 'Marshall Amps' started by cgtrman, Nov 7, 2019 at 10:22 PM.
  1. cgtrman
    cgtrman Member
    Aug 29, 2011
    32
    13
    This amp might be my fave amp of all time, but I have a recurring issue. When I first power it up, there is 20-30 seconds of static and white noise regardless of anything connected to the input. It will die out and not return until my next power-up.
    A friend suspects a plate resistor might be to blame. Im hoping a preamp tube is the culprit. Any recommendations?
  2. South Park
    695
    431
    It’s things just powering up . Avery amp is a little different. It is what tubes do
    cgtrman, tce63 and BanditPanda like this.
  3. cgtrman
    cgtrman Member
    Aug 29, 2011
    32
    13
    Changing power tubes wont fix it?
    tce63 likes this.
  4. ampmadscientist
    13,811
    7,658
    This is not normal, and it is not " what tubes should do."
    Replace the preamp tubes one at a time with a new 12AX7 and re-test the amp every time you swap one out w/ the new tube.
    If there is a bad tube you will find it.
    Most common cause of crackle in guitar amps is the preamp tubes. (it's usually one tube that does it)
    2. If the sockets contacts get oxidized it can also cause this to happen.
    A small amount of Deoxit G100 in the socket contacts will cure that problem.
    3. There is no reason to imagine that this is caused by a resistor.
    You need to find evidence before you reach that conclusion.
    Repairing guitar amps by guessing / random parts replacement generally gets you nowhere.
    It is "possible," but more commonly it's a preamp tube that's causing it.
    And I say this based on long term experience not guessing.
    4. Plug a guitar cable between send and return of the effects loop. Then re-test the amp.
  5. MarshallDog
    Nov 28, 2010
    11,809
    10,732
    Taintville
    Try preamp tubes first. I had this happen before to more than one amp and it was a preamp tube. Good luck!
  6. Phony iommi
    Phony iommi Well-Known Member
    Mar 16, 2019
    191
    319
    Not to divert the op here, but what diagnostics does plugging a cable into the send and return of the fx loop provide? What should happen when you do it?
  7. Mitchell Pearrow
    7,961
    11,554
    What was said before me, and check that your volume is on 0, when you power up!
    Cheers Mitch
    cgtrman and tce63 like this.
  8. cgtrman
    cgtrman Member
    Aug 29, 2011
    32
    13
    Thanks for all the great feedback and recommendations. I will start w swapping preamp tubes one at a time.
    tce63 likes this.
  9. Mitchell Pearrow
    7,961
    11,554
    On my lead 100 mosfet it does away with volume swells.
    cgtrman likes this.
  10. cgtrman
    cgtrman Member
    Aug 29, 2011
    32
    13
    Would a preamp tube exhibit statis and white noise as it warms up, then go away?
  11. Mitchell Pearrow
    7,961
    11,554
    Good question, and I cannot answer it !!
  12. Arc Anjil
    Arc Anjil Active Member
    Dec 26, 2012
    133
    101
    Florida
    My O50h does that hissing noise on power up/warm-up, too. Only on the 50 watt setting, though, not the 10 watt. I've rolled the pre-amp tubes and nothing has changed.
    Once warmed up it's all good.
    cgtrman likes this.
  13. cgtrman
    cgtrman Member
    Aug 29, 2011
    32
    13
    Interesting. Mine occurs on all three pwr settings.
  14. ampmadscientist
    13,811
    7,658
    Now you are on the path to enlightenment.
    Mitchell Pearrow, cgtrman and tce63 like this.
  15. ampmadscientist
    13,811
    7,658
    Did you bypass the effects loop w/ a patch cable?
  16. cgtrman
    cgtrman Member
    Aug 29, 2011
    32
    13
    I will be able to do that tonight along with preamp swaps. W fx loop test, do I need to plugin footsw cause I never use the fx loop?
    tce63 likes this.
  17. cgtrman
    cgtrman Member
    Aug 29, 2011
    32
    13
    I never use the fx loop. I place a jumper in fx loop and the noise and static are the same. What is the purpose of that test?
    tce63 likes this.
  18. cgtrman
    cgtrman Member
    Aug 29, 2011
    32
    13
    I replaced each preamp tube one at a time, no change. I will replace power tubes tomorrow.
    One more clue: it makes static and intermittent white noise w master vol at zero.
    tce63 likes this.
  19. Mitchell Pearrow
    7,961
    11,554
    I am sorry for your troubles with your amp brother, I am no tech, but my 2 Origin 50H’s have had no problems whatsoever.
    I do hope you’re able to get this corrected.
    Mitch
    MarshallDog, tce63 and cgtrman like this.
  20. Arc Anjil
    Dec 26, 2012
    133
    101
    Florida
    No. It happens with or without using the loop and footpedal connected.
