Marshall Museum Bletchley "No One Amp" Replica Build on Old Chassis
Discussion in 'Building the Classics' started by pleximaster, Jan 12, 2020.
  1. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,482
    1,526
    I was building a replica of the so called "No One Amp" that Jim Marshall called it. Its been debated whether or not this was the actual chassis that was the first one and the one demoed at that Ealing Club sometime in September 1963 (not 62). Lest leave it at that.
    However, the reson for this replica build came from the urge to find out what that chassis sounded like, with those rare Elstone transformers. In the build process of the previous thread I was approached by a member here to restore an old chassis that had been parted out as the previous owner thought it was a home-brew amp. I got curious and and excepted to restore it. It came last week and I had all the other parts ready for my own build on a blank chassis. My own chassis hadn't been cut for valves and pots so I could not help myself putting a functional chassis together. Will get other parts for my own build...
    Here was the stripped chassis... 1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 9.jpg
    And this is how it turned out. I copied it from at the Chassis at the museum down to the obvious changed parts like the sprague on the presence knob, the later 60´s diode. It has vintage Mullards ecc83´s a Mullard GZ34 and Brimar 6L6/5881 valves. Almost all the same manufacturer, tolerance and specs. The brown rectangular RS 0.1uF coupling is 600 cold instead of 400volt. The grey filter cap is slighty thinner but longer than on the original No One. Wirings to the input jack differs as I left them as they were from the stripped chassis. The original inside filtercap in the old stripped chassis is replaced as it did not reform.
    Same McMurdo 9-pins valve sockets for the preamp valves as the No One. Cinch bakelite valve sockets for octals. RS 7x27 hole board. Original potentiometers and correct valve with the Bass and Mid control in switched places as an old Fender Bassman.
    In fact all parts on the No One amp is 100% clone of the 1959 Bassman but with British equivalent parts.
    I added a 250uf on the first 820 ohm on the board, this one is missing on the No One chassis (But must have been there) I also mounted the 150k dropping resistor for the board instead of a flying one as on No One amp (Safety reasons)
    The sound astonished me as it had tones of gain and quite bright. The OT saturates very fast.
    Thanks the best plexi
    The chassis with snowwhite background is the original No One Amp... the pics on the right is the replica build on that old stripped chassis... :)
    TAZIN, mAx___, shakti and 7 others like this.
  2. pleximaster
    Feb 6, 2012
    1,482
    1,526
  3. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    590
    225
    Which one is the real one again? The right or was it the left?
    pleximaster likes this.
  4. pedecamp
    13,629
    9,929
    Sounds good :yesway:
  5. Dblgun
    Dblgun Member
    Jan 6, 2019
    86
    97
    AZ
    Great piece of history and your work is top notch. Thanks for sharing.
  6. ricksdisconnected
    Aug 11, 2019
    1,012
    1,560
    we can do that?
  7. South Park
    1,232
    927
    Great job . It being proto type amp it is hard to say what changes may have Ben made that long ago. Only the builder knows what went into it . No matter how close you get it is a pease of history
  8. tomsvintage
    tomsvintage Well-Known Member
    Jun 11, 2012
    698
    492
    JTM45 Headquarters
    Another job well done to say the least !!!! Excellent reproduction and amazing sound :) A clear acrylic cab could house that one !!
  9. pleximaster
    Feb 6, 2012
    1,482
    1,526
    An acrylic cab is the plan for these! :)
    plexi
  10. pleximaster
    Feb 6, 2012
    1,482
    1,526
    However, this whole project should not be taken as a serious scientific experiment! :) The only serious thing about it is too hav e some serious fun while doing it! ;)
    Keep Calm and Carrey on Amping! :=)
    plexi
    mAx___, Dogs of Doom and neikeel like this.
  11. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    707
    394
    Those two chassis are so similar, very eerie.
  12. shakti
    shakti Member
    Jul 14, 2016
    93
    54
    Superb job, even the slightly crooked capacitor alignment copied!
  13. pleximaster
    Feb 6, 2012
    1,482
    1,526
    I got the parts from you today! Thanks a lot! Your parts will go into the build that is for me!
    did the parts I send to you arrived yet?
    best plexi
  14. Seanxk
    Seanxk Active Member
    May 14, 2018
    155
    98
    Superb work, really great to see things back and moving along nicely.
  15. pleximaster
    Feb 6, 2012
    1,482
    1,526
    Just from memory this is what parts you need for building a replica of No One Amp!
    plexi
    Replica build parts list
    1 x chassis
    4x corner mounts
    1 x Bulgin jack mains
    1 x Bulgin fuse
    3 x Bulgin switches
    6 x RS/AB pots (3 x 1Meg, 1 x 20k, 1 x 250k, 1 x 5k)
    5 x old Rendar input jacks Black nuts, metal washers
    2 x 1k 1 watt amp resistor
    1 x 4,7k 1 watt amp resistor
    2x27 hole paxolin board
    50 x vintage turrets
    3 x McMurdo 9-pin valve sockets
    3 x Cinch octal valve sockets
    1 x 550-556 pf silver mica
    1 x 250 pf silver mica
    1 x 47uf silver mica
    1 x 250 uf grey RS electrolyte
    1 x 100 pf red dog bone RS cap
    1 x 8 uf 450 v RS electrolyte
    5 x 0.02 uf RS grey Paper in oil caps
    2 x 0.1 uf RS grey Paper in oil caps
    1 x 0.1 uf RS brown box cap
    1 x 0.1 sprague black beauty cap
    2 x vintage cap holders
    1 x 16 uf 450–500v
    1 x 32-32 uf 450-500v
    Valves
    3 x ecc83
    2 x kt66
    1 x gz34
    1 x set Elstone transformers (OT MT choke)
    1 x red pilot lamp
    1 x RS grey snubber cap
    1 x RS grey polarity cap
    4 x screws for board mount 6BA
    4 x aluminium distance for board mount
    6 x screws 6BA for 9-pin socket mounts
    6 x rubber grommet sets for for 9-pin socket mounts
    5 x rubber grommets 9 mm for wires
    10 x lug ear mounts
    20 x anti shock washer for 6BA
    16 x anti shock washers for 4BA
    16 x 6BA counter sunk screws for mounting corner mounts
    18 x 4BA nuts
    34 x 6BA nuts
    1/2 vintage carbon comp resistors
    4 x 68k
    5 x 100k
    2 x 820 ohm
    2 x 270k
    2 x 56k
    4 x 1 meg
    1 x 470 ohm
    1 x 10k
    1 x 82k
    2 x 220k
    1 x 150k
    1 x 15k
    1 x 27k
    1 x 10k 2 watt
    1 x 470k 2 watt
    2 x 470 ohm 2 watt
    Wires
    Black
    White
    Red
    (yellow)
    Blank buzz-wire
    tomsvintage, marshalltsl and Seanxk like this.
  16. pleximaster
    Feb 6, 2012
    1,482
    1,526
    Gathering another batch of parts for my own chassis. Will copy holes and layout from the old stripped chassis!
    One problem with these replicas is that they eat out my stash of old parts. Usually I miss a nut or a screw here... :) a socket there a wire over there ... But here with a replica it really empties my saved parts... :)
    plexi
    tomsvintage, TAZIN, shakti and 3 others like this.
  17. pleximaster
    Feb 6, 2012
    1,482
    1,526
    tce63, marshalltsl and tomsvintage like this.
