Marshall mg30dfx line out/internal speaker
Discussion in 'Marshall Amps' started by R.L., Jan 26, 2020.
  1. R.L.
    R.L. New Member
    Jan 26, 2020
    4
    Hey, I recently purchased a MG30dfx to use at church because of its size and internal effects. Problem I am having is I want to use the emulated line out AND the internal speaker for stage volume. I'm sure I can make adjustments to the headphone jack to use both at the same time, but I am worried that doing so will put too much strain on the amp. Had anyone done this is have any suggestions? We are not using stage monitors, but in-ear monitors. Just wanting stage volume. Or should I just mic it ???
  2. ampmadscientist
    15,494
    9,382
    "I want to use the emulated line out AND the internal speaker for stage volume."
    That's no problem go ahead and do it. It doesn't strain anything it's OK.
    R.L. and Mitchell Pearrow like this.
  3. Vinsanitizer
    Vinsanitizer 1st new member 2020 VIP Member
    Oct 19, 2012
    25,540
    17,809
    If you want to use the headphone out and send 1 signal to headphones and 1 to the house (because you're on a silent stage), then you need a small mixer of some sort.
    Here's one example. There may be cheaper options, but I found this in a quick search. This one can split any signal 4 ways, $65. Perhaps other members can offer a better suggestion, but my point is that you should use a mixer or some kind of proper headphone splitter, and never a Y cable:
    https://www.amazon.com/ART-SPLITMix...=2025&creative=165953&creativeASIN=B002VX0DCE
  4. pedecamp
    13,819
    10,217
    Hook it up and crank it, thats what its made for. :yesway:
  5. Mitchell Pearrow
    9,099
    14,042
    Welcome to the forum, as far as I know you can use line out and internal speaker with no harm whatsoever, I used to use the line out to another small amp.
    And had no issues at all.
    Cheers Mitch
    scozz, Vinsanitizer and R.L. like this.
  6. South Park
    1,438
    1,080
    Solid state amps are not likes tubes the power section is a switch and gets hot if you crank it . the line out is not the problem . As long you don’t max it out all day you are good . I must be great feeling to be rock star to your church
    Mitchell Pearrow and R.L. like this.
  7. R.L.
    R.L. New Member
    Jan 26, 2020
    4
    Thanks for the info! I plan on opening the amp up tomorrow and bypassing the switch on the headphone jack that turns off the speaker when I plug into that jack!
  8. R.L.
    R.L. New Member
    Jan 26, 2020
    4
    "Rock Star"! Lol! Far from it, but it is fun! Thanks for the reply, I plan on altering the jack tomorrow to accomplish the task!
  9. ampmadscientist
    15,494
    9,382
    The trick the the headphone jack is to plug a cable in 1/2 way, and it won't shut off the speaker.
    However since those headphone jacks fail a lot, bypassing is probably a good idea.
    scozz, Mitchell Pearrow and R.L. like this.
